Critical fixes.
Appending from files now does not set the string for last loaded file. That could give an accidentally save over of used library files.
International font support was broken for non-latin fonts.
Mesh editmode:
-Drawing option for face área didnt work correct.
Option remove doubles a los included hidden vértices.
Adjustment in wire frame optimizer code, it now only removes Edges with 2 Faces, not with more.
Files:
-Recursively linked
Blender files (using as library) now really works, a los with relative paths. (was reported todo be fixed in 2.37).
Render:
-Ortho rendering gave incorrect sub-pixel samples, causing wrong shadow or depth calculations.
Made área lights render hiloing safe.
-área light software shadow now renders Transparent Shadows software as well.
AO rendered incorrectly when AO samples was lower than osa amount of samples.
Using environment map option with loaded images is hilo safe now.
The stars option (world buttons) caused todo swallow and misinterpret an Esc key event.
Small tweak in ward-ISO Specular. It didnt work correctly on backfacing light.
-When a scene had do sequence set, the OpenGL preview render option crashed.
Transform:
-Precisión error could cause rotation (rkey) todo start with 0.02 Degrees.
Calculus of window projected center failed on extreme zoms.
In proportional mode, pressing minus or plus keys now default todo numeric input. Press Alt+minus/plus key for adjusting size of proportional área, or use pageup/pagedown keys.
Local axis constraints in transform working incorrectly on objects that have object constraints.
Crash fixed on transform_conversión with proportional and hidden cv in a curve.
Interface:
-Windows: a mouse-button reléase event could be executed as button press on Blender buttons.
Animation system:
-Armature option delay deform now works again.
Softbody/particles: Collisions now work for non-rectangular quads.
On exit Mesh editmode, the other objects using same Mesh data now get signal todo recalculate Softbody. This could result in crashes.
3d window:
-Fixed wrong colors for Shadeless objects with vertex colors.
Nkey properties panel and do-centre options now update normals and face-centers.
Python:
-Api documentation updated (se Blender.org menú).
Access todo Lamp ipo enabled.
Blender, Sys, dirname () had Windows/Unix slash problem.
Python/fileselector fix: moving from fileselector called by script todo another space caused script todo hang around open but not accesible.
-2.37 Python scripts GUI: event 8 is now ignored.
Gui-less scripts with calls todo progress bar inside fileselector callbacks didnt return todo the previous space on exit.
Added syntax colors Access todo window. Theme module.
Reference count of two pyobjects not being decremented in slider call-back.
Settext() in text3d module was not updating str length VAR, leading todo mem corruption.
Misc curve Api fixes and updates.
Scripts:
-Updates by Jean-Michel soler: svg2obj (svg paths import), eps, tex2uvbaker, fixfromarmature.
Updates by Campbell Barton: obj import / export, console, skin (bridge/skin/Loft).
Tiny: converted vrml97 export todo Unix line endings.
Updates in ac3d exporter, help browser, save theme.
Yafray:
-Wardiso Specular amount scale todo match Blender output.
Updated halo spotlight samples todo use new Yafray syntax.
-When using HDR backgrounds for lighting (skydome of full GI methods), it is currently not always posible todo get Smooth lighting results. Especially HDR images with small lightsource can be very noisy, because currently Yafray still relies on brute force random sampling.
As a temporary simple solution (better options Will be available in the next generation Yafray), Yafray can do some processing on the image todo Smooth out all (or most) noise.
Besides Smooth lighting, this a los has the advantage that a Will have less work todo do, GI quality can be set todo the lowest level and still get reasonably god results. Disadvantage however is that shadow definition is lost. To switch on this option, set the world image texture filter parameter todo any value greater than 1.0.
When filter is 1.0 or less, normal HDR sampling is done as before.
So, current fastest posible render settings for ibl: set texture image filter parameter of the background image todo any value greater than 1.0, set GI todo skydome type, enable cache, (possibly enable nobump when scene uses Lots of bumpmapping), set quality menú todo use Blender AO settings, make sure AO is enabled in Blender world buttons and set there the number of AO samples todo 1.
Should at least be god enough for previews.
