    Jan 2023
    Exclamation Octoprint ha dejado de mostrar la raspicam
    Hola a todos, buenas tardes, yo tengo una Raspberry Pi 3 B+ con octoprint y una raspicam para ver las impresiones desde cualquier lugar, hasta que se actualizó octoprint a la versión 1.8.6 funcionaba la webcam pero ahora no consigo hacer funcionar la cámara.
    ¿Alguien podría ayudarme? El fichero octopi.txt lo tengo así (antes funcionaba y sin tocar ahora ya no):
    Código:
    # mjpg_streamer release do not support the -f parameter (for specifying
    # the capturing framerate) and will just refuse to output an image if it
    # is supplied.
    # The webcam daemon will detect those devices by their USB Vendor and Product
    # ID and remove the -f parameter from the options provided to mjpg_streamer.
    # By default, this is done for the following devices:
    #   Logitech C170 (046d:082b)
    #   GEMBIRD (1908:2310)
    #   Genius F100 (0458:708c)
    #   Cubeternet GL-UPC822 UVC WebCam (1e4e:0102)
    # Using the following option it is possible to add additional devices. If
    # your webcam happens to show above symptoms, try determining your cam's
    # vendor and product id via lsusb, activating the line below by removing # and
    # adding it, e.g. for two broken cameras "aabb:ccdd" and "aabb:eeff"
    #   additional_brokenfps_usb_devices=("aabb:ccdd" "aabb:eeff")
    # If this fixes your problem, please report it back so we can include the device
    # out of the box: https://github.com/guysoft/OctoPi/issues
    #additional_brokenfps_usb_devices=()
    ### Additional options to supply to MJPG Streamer for the RasPi Cam
    # See https://faq.octoprint.org/mjpg-streamer-config for available options.
    # NOTE: Newer raspi cam modules are reporting as usb devices causing these
    #       options to be ignored. Set `camera="raspi"` to avoid these issues.
    # Defaults to 10fps
    camera_raspi_options="-x 1920 -y 1080 -fps 30"
    ### Configuration of camera HTTP output
    # Usually you should NOT need to change this at all! Only touch if you
    # know what you are doing and what the parameters mean.
    # Below settings are used in the mjpg-streamer call like this:
    #   -o "output_http.so -w $camera_http_webroot $camera_http_options"
    # Current working directory is the mjpg-streamer base directory.
    camera_http_webroot="./www"
    camera_http_options=""
    ### EXPERIMENTAL
    # Support for different streamer types.
    # Available options:
    #   mjpeg [default] - stable MJPG-streamer
    Y la página de stream configurada en octopi es: "https://"direccion ip de la raspberry"/webcam/?action=stream"
    También he probado con "localhost....., con 127.0.0.1.....
    Lo curioso es que no he tocado nada, de repente ha dejado de funcionar, me dice:
    Transmisión de la cámara web no cargada. Es posible que no esté configurado correctamente o que requiera autenticación. En "Ajustes" > "Webcam & Timelapse" > "Webcam" > "Webcam" > "Stream URL" puede modificar la URL del streaming. Si no tienes una cámara web, también puedes desactivar el soporte para cámaras web allí.URL de stream configurado actualmente: https://"dirección ip de la raspberry"/webcam/?action=stream.
    Un saludo a todos y espero que alguien sepa por lo que es, tiene que ser una chorrada pero no doy con ella, gracias.
    Si Octoprint ha dejado de mostrar la cámara de la Raspberry Pi, es posible que haya un problema con la conexión de la cámara o con la configuración de Octoprint. Aquí hay algunos pasos que puedes seguir para solucionar el problema:
    Verifica la conexión de la cámara: Asegúrate de que la cámara esté conectada correctamente a la Raspberry Pi. Puedes desconectar la cámara y volver a conectarla para asegurarte de que esté bien conectada.
    Verifica la configuración de la cámara en Octoprint: Asegúrate de que la cámara esté configurada correctamente en Octoprint. Puedes ir a la pestaña "Control de Cámara" en la interfaz de Octoprint y asegurarte de que la cámara esté habilitada y configurada correctamente.
    Verifica la configuración de Octoprint: Asegúrate de que la configuración de Octoprint esté correcta para el uso de la cámara. Puedes ir a la pestaña "Configuración" en la interfaz de Octoprint y verificar la configuración de la cámara en la sección "Cámara".
    Verifica la conexión de red: Asegúrate de que la Raspberry Pi esté conectada correctamente a la red y que Octoprint esté configurado correctamente para el acceso a la red.
    Si después de estos pasos todavía no puedes ver la cámara en Octoprint, es posible que haya un problema con la cámara en sí. En ese caso, es posible que necesites reemplazar la cámara o buscar ayuda adicional para solucionar el problema.
  1. OctoPrint - Plugin Google Drive Backup
    Por javichuteck en el foro Impresoras 3D
    Último mensaje: 02-01-2024, 13:30
  2. Raspberry Pi 4 para Octoprint en Crelity Ender 3
    Por 3dpoder en el foro Impresoras 3D
    Último mensaje: 01-01-2024, 13:20
  3. 3ds Max OctoPrint novedades y características
    Último mensaje: 28-05-2023, 15:47
  4. 3ds Max Control remoto de impresoras 3D Octoprint
    Por juancarlos en el foro Problemas con Programas
    Último mensaje: 27-12-2022, 09:44
  5. Octoprint y Kit Raspberry
    Por JLF en el foro Impresoras 3D
    Último mensaje: 27-09-2022, 20:52
