Resultados 1 al 10 de 28
    Administrador
    Wings3d Wings3d 0-99-xx release y avances
    Wings3d 0.99.00a. Después de poco más de un año sale una nueva versión de este potente, versátil y ligero programa de modelado open source.
    Ya sabéis, descarga gratuita en Wings 3d.
    Development reel: 0.99.00a.
    Mac | win | Linux | source | notes.
    Tutoriales: videotutoriales en castellano
    videotutoriales recopilados en 3dpoder
    Wings 3d - Foros 3dpoder..
    Notas:
    Cita Iniciado por örn
    here is the new release. It is based on erlang/otp r12b.
    I have tested the Mac versión on both Mac os 10.4 (pc) and Mac os 10.5 (Intel).
    I have tested the Windows versión on Windows XP (sp2), running in Parallels.
    (a virtual computer) on my Imac.
    I have tested the Linux versión on openSUSE 10.3, running in Parallels on my.
    Imac. I hope that it should work on all modern Linux systems.
    If there are any obvious problems in this reléase that are easy todo fix, there might be another reléase before Christmas.
    Enjoy.
    /björn.
    Cosmetic improvements: the menú selector has a subtle gradient, and the title.
    Bars have the common aqua/vista effect. Alos added optional history buttons.
    (aka undo/redo) and open/save icons on menubar. [scorpius].
    Added more Shaders (brick, ton, environment-mapping, goch-tone), which can.
    Now be toggled (or cycled) th rouge a choice in the view menú. Requires an.
    OpenGl 2.0 video card. [scorpius].
    Revised most primitives, they are now more accurate and have more options.
    [contributed by Richard Jones (optigon)].
    Ability todo set drag constraints for the currently pressed modifier key(s), when one Edge is selected the distance constraint is set, when two are.
    Selected the rotation constraint is set. [scorpius & optigon].
    Added ISO-8859-9 font support. [contributed by ismail keskin (devilgren)].
    Added search in relative paths when loading textured models. [dgud].
    Ability todo set drag constraints. [contributed by Richard Jones (optigon)].
    Small add todo right mouse button absolutesnap, now you can look movement.
    In x, y or z. [giniu].
    Changes todo absolute scale, ability todo enlace sizes (uniform scale), ability todo.
    Pik scale centre from scene using RMB absolute scale, ability todo pik target.
    Size from scene using Mb absolute scale and option todo fit selection into.
    Picked target by automátically adjusting scale centre. [giniu].
    Pov-Ray exporter and renderer added.
    [contributed by Chris hegarty (avariant)].
    Added a live miniature-axis icon todo the lower-left corner of the screen.
    [scorpius].
    Added a user defined clipping-plane. Use set default axis todo interactively.
    Change the orientation of the plane.
    Edges can now be displayed with antialiasing, se preferencias. [scorpius].
    Added russian translation by Paul geraskin. [Bjorng].
    Major update todo portuguese translation [contributed by: luiz fonte boa]. Wings 3d.
    Última edición por SHAZAM; 19-12-2007 a las 01:58
    Wings3d 0-99-00a release
    Descargando. Leyendo. Eh? Cómo? Un año, y solo media página de cambios. (Es broma.
    En slackware 12.0 en principio funciona.
    Administrador
    Posiblemente haya otra actualización esta semana. Esperemos que no sea de media página.
    Feb 2005
    Tiene pinta de ser sencillo de utilizar, ¿sabéis donde encontrar tutoriales de calidad para utilizar este programa? Un saludo.
    Esperando noticias de Autodesk.
    Feb 2005
    Vaya, me parece que le he pillado ya el truco. Este programa se puede utilizar de forma comercial gratuitamente o hay que pagar?
    Administrador
    Es opensource, puedes hacer lo que te plazca con él.
    Sencillo, potente y más utilizado de lo que se piensa y dice.
    Feb 2005
    Thumbs up Wings3d 0-99-00a release
    Gracias Shazam, eres grande.
    Es opensource, puedes hacer lo que te plazca con él. Sencillo, potente y más utilizado de lo que se piensa y dice.
    Tutoriales: videotutoriales en castellano. videotutoriales recopilados en 3dpoder. Wings 3d - Foros 3dpoder..
    Administrador
    Wings3d 0-99-00a release y avances
    Wings-0.99.00b.
    notes:
    - Creating a Normal Map for a material was so Slow so that it semed.
    That Wings was Frozen. Now bak todo normal speed. [Bjorng].
    Attempting todo create or edit a material when the Yafray plug-in was active.
    Would cause a crash. Corrected. [Bjorng].
    Eliminated the problem that caused some lenguaje files todo be corrupted.
    On Windows. Alos added verification todo the the build process so that.
    This problem Will be detected if it should occur again. [Bjorng].
    In the Misc tab in edit | preferencias, Camera moves and interactive commands.
    Are Jumpy is now default on all versións of Mac OSX. A buggy versión number.
    Chek turned it of on Leopard. (gracias todo jtico.) [Bjorng].
    http://switch, dl.sourceforge.net/so...s-0.99.00b.exe. Saludos, ala2.
    Tresmiltornillero
    ¿Solo tiene 1 nivel de Subsurf con shift-tab?
    Administrador
    Buena pregunta.
  1. Blender 2.61 release y avances
    Por SHAZAM en el foro Noticias
    Respuestas: 64
    Último mensaje: 27-02-2012, 22:28
  2. Blender 2.60 release y avances
    Respuestas: 89
    Último mensaje: 14-12-2011, 21:29
  3. Wings3d 0 99 04 release
    Último mensaje: 11-10-2008, 04:33
  4. Wings3d 0 99 03 release y avances
    Último mensaje: 21-07-2008, 13:07
  5. Houdini 9 1 124 release y avances
    Respuestas: 25
    Último mensaje: 07-02-2008, 02:35
