    Administrador
    Softimage Xsi :: softimage|xsi 6 mod tool versión de aprendizaje y mod gratuita ::
    Softimage|XSI 6 mod tool (versión gratuita)
    Fre, 3d modeling and animation software for aspiring.
    Game developers and modder.
    Por fin. Ya era hora de que está versión se actualizara, equivalente a la ple de Autodesk Maya, es decir, la versión gratuita de XSI perfecta para aprender el programa.
    Además, de servir para el aprendizaje de este gigante de la industria es una herramienta perfecta para la creación de personajes y props para videojuegos como Half Life 2, por ejemplo.
    Más información y descargas: http://www.Softimage.com/products/modtol/. descargar XSI mod tool.
    características:
    Mod tool is packed with the same 3d modeling and animation tools that the pros use todo create triple-a titles like Half Life 2, including:
    • the world fastest subdivisión surface modeler, so you can work eficiently with intuitive XSI tools that make 3d modeling fel like sculpting.
    • the worlds best polygon reduction engine: works reliably with millions of Polygons, quadrangulates meshes, and preserves volume and detail.
    • fast, flexible animation tools that make it easy todo postura and keyframe your characters.
    • an interactive texture editor that lets you unfold UVS and place texture maps precisely.
    • UltiMapper: generate generate normal, Ambient Occlusion, diference, light, and albedo maps in just a few clicks.
    • net view: a built-in web browser that you can use todo Access the tools, sample content, and training material that comes with mod tool.
    ________________.
    limitaciones.
    Xsi mod tool versión limitations.
    Most of the features and functionality of the commercial versión of Softimage|XSI 6 are enabled in mod tool, without the hassle of licensing. Data from all sources can be brought into the XSI mod tool, including data from the commercial versión of Softimage|XSI. Mod tool is for non-commercial use only.
    Before installing mod tool, por favor be aware of the following limitations:
    Mod tool does not support polymatricks. XSI transforms are fully supported.
    Mod tool supports only dxfx and CGFX material types. Mental Ray materiales are not supported.
    Mod tool supports only polygonal Mesh primitives.
    Exported geometry is limited todo 64000 triangles.
    The Mental Ray renderer is used only for rendermap and UltiMapper. All other Mental Ray rendering is disabled.
    Maximum resolution for UltiMapper maps is 512 por 512.
    Images output using the hardware renderer are limited todo a máximum resolution of 512 por 512.
    Algunos videotutoriales:noesis quick start: mod tool overview
    A deper look into the mod tool interfaz and toolset. Master the essential skills neded todo start creating custom content.
    download.
    noesis quick start: Dynamite modeling.
    Learn useful modeling techniques and create your first game-ready prop with this easy todo follow lesson.
    download.
    noesis quick start: source prop integration
    Prepare and export a custom XSI model for integration into valves half-life2. Then assing parameters and wreaque havoc in a simple Half Life 2 level. download
    Ppara aquellos que se sientan atraidos por este programa, es una buena forma de comenzar. Saludos.
Nombre: XSI-6_mod-tool.jpg
Visitas: 3636
Tamaño: 24.8 KB
ID: 54976   Clic en la imagen para ver su versión completa.
Nombre: police.png
Visitas: 3682
Tamaño: 68.5 KB
    Última edición por SHAZAM; 18-01-2008 a las 04:48
    pythonized...
    :: softimage|xsi 6 mod tool versión gratuita ::
    Qué bueno que lo actualizaron, se había quedado bastante atrasado con respecto a sus hermanos mayores. Para hacerse con la interface y las herramientas de modelado supongo que, está muy bien, es una buena forma de conocer la esencia de XSI sin depender de un trial, me alegro por la noticia.
    Administrador
    Olvidé decir que el enlace del cuarto video (viewports) está roto en la web oficial, aquí está corregido. Saludos.
    BlenderAdicto
    Jun 2002
    Qué bueno.
    A ver si saco tiempo para probarlo, el antiguo mod tool estaba muy bien. Gracias por la noticia, Shazam. Saludos.
    La vida es lo suficientemente larga para que sucedan cosas y lo suficientemente corta para no esperar que vengan por si solas.
    http://resources.blogscopia.com - Modelos 3D gratuitos
  1. XSI Cómo entrar en el modo mod tool en Softimage XSI 7 5
    Por roiginbag en el foro Problemas con Programas
    Último mensaje: 03-04-2010, 14:40
  2. Problemas para instalar Softimage XSI mod tool
    Por MATRIX 003 en el foro Problemas con Programas
    Último mensaje: 04-11-2008, 11:14
  3. Respuestas: 15
    Último mensaje: 11-02-2008, 23:18
  4. 3ds Max 9 versión de aprendizaje
    Por SHAZAM en el foro Noticias
    Respuestas: 19
    Último mensaje: 29-12-2006, 15:44
  5. Maya ple v7 0 versión gratuita para aprendizaje
    Respuestas: 45
    Último mensaje: 09-10-2005, 07:52
