    Viva Blender !!!
    Apr 2006
    3ds Max 9-0 32 bit hot fix 1 y 2
    Hola. Quisiera saber si algunos de ustedes a instalado los dos. Hotfix para max 9.0 y como le han funcionado.
    más información. http://usa.Autodesk.com/adsk/servlet...linkid=5573636. Suerte.
    Suerte
    This Hot fix Package resolves the Shockwave issue where the exporter is missing from the product install. This resolves the same issue as hotfix 0.1, the only diference is that it is rolled into an hotfix installer.
    This Hot fix Package resolves the problem of the DX material who was unable todo use UV channels higher than 1.when installing Hot fix 2, you Will a los install Hot fix 1, it is only for 32 bit build.
    Según explican, son 2 tonterías las que han arreglado con los hotfix, estos.
