Resultados 1 al 10 de 14
    Re Member
    Audi : filter
    Hola. Un spot que me ha gustado mucho:
    Audi : filter
    http://www.youtube.com/watch?v=b8238fogyh8
    Hq : http://motionographer.com/theater/Audi-filter/
    Audi : filter - Making of
    http://www.youtube.com/watch?v=s5igotqkrba
    Hq : http://motionographer.com/theater/Au...ter-making-of/.
    ¿Alguna idea de cómo han renderizado las partículas? ¿con Krakatoa quizás?
    Monigote al ralent
    Audi : filter
    Brutal.
    Blender por diversión Avatar de Pit [reloaded]
    Audi : filter
    No está mal, no.
    pythonized...
    Audi : filter
    Las renderizaron con XSI usando Mental Ray y el volume Shader nativo, en el mailing list de XSI se comentó bastante sobre el tema.
    To answer your question: the workflow was XSI only. We used emfluid for.
    Some takes (which was luckily anonced just at the momento we started with.
    The Project). The rendering was done with the volumeshader. Really hard.
    To setup for some takes, but it works so the workflow was mostly ->.
    Setup and design of the simulation -> caché writting (which eats a lot.
    Really a lot, harddrive space). Loading bak the cache, some duplication.
    Of the cached particles with clone point, setting the size of the.
    Particles and finally setting up the volume Shader and the light(s).
    Chers.
    Tim.
    No i first thought we should use Krakatoa and Fume FX.
    And try todo get it it done in in max and XSI.
    But i wanted todo use mainly XSI. When i started the research.
    How we could do the fluid Stuff, there was no bien todo do it in.
    Xsi, y played a Little bit with the Maya fluidos and remembered.
    That i started todo code an importer for Maya fluid caches some.
    Time ago.
    After a bit of digging i had a Prototype in Python which was working, todo use the caches as flowfield, but in the second wek of research.
    The nice emfluid was ported todo ice and we gave it a go.
    Quite easy todo use and as a node in ice quite powerfull.
    You could enhance the resolution of the simulation with simple.
    Turbulence nodes, for example using the velocity as a multiplier.
    For the turb or the turb size.
    Rendering was an other thing, first we wanted todo stay away from.
    Selfshadowing and do something in comp, but After i set up the first.
    Shot with shadows, just for fun, it was not that problematic.
    As i thought, everything on 64 bit because of the massive data amount.
    Some shots with over 50 mío particles - Mental Ray was quite nice todo us.
    It was a bit painfull, because we had todo tune the Shader settings of every shot seperately, there was no bien todo use settings from other shots, the volume Shader worked quite well but its hard todo tune.
    We found one limit with the Mental volume thing - You could not.
    Allocate more than 4 gig.
    The other nice thing is - Youre not used todo produce such an large amount.
    Of data with caché files. We had around 1 terra of caché files.
    Only with the pointposition because of the file size, then we loaded it bak in ice and calculated the size, velocity etc on the flow.
    Otherwise it would have killed our server.
    3 months of hard work in the production submarine, but tim and me had.
    A nice time.
    Última edición por Cesar Saez; 17-04-2009 a las 18:22
  5. Gracias itstimetodraw Agradece este post
  6. #5
    Re Member
    Audi : filter
    Muchas gracias, César.
  7. #6
    Feb 2007
    Audi : filter
    Vaya, la verdad es que XSI es otro programa magnífico, yo lo estoy aprendiendo y empecé con el módulo de modelado, y la verdad es que es una gozada, probablemente el que mejor he usado.
  8. #7
    Re Member
    Audi : filter
    A mí también me está gustando mucho este software.
  9. #8
    Audi : filter
    También lo estas probando?
  10. #9
    Re Member
    Audi : filter
    Probarlo no, estoy estudiándolo. Me quedan unos meses duros.
  11. #10
    Audi : filter
    Pit, este tío no es normal. Excelente video. Me quedé impresionado cuando lo vi. (Si tienes que, aprender Mental, y aprendes algo sobre settings, tu amigo Borja te lo agradecerá).
  1. Respuestas: 1
    Último mensaje: 07-04-2023, 19:14
  2. Selection filter
    Por Vanguardia en el foro Problemas con Programas
    Último mensaje: 04-01-2013, 13:53
  3. Nodes filter
    Último mensaje: 12-09-2008, 14:46
  4. Select filter
    Por Keroki en el foro Programación y Scripts
    Último mensaje: 25-06-2008, 12:11
  5. Filter AutoCAD
    Por rubbin en el foro Programas de Diseño gráfico y CAD
    Último mensaje: 04-10-2005, 00:05
