    Administrador
    Wings3d Wings3d 0-99-03 release y avances
    Lista para descargar. Mac | win | Linux | source. Wings 3d
    reléase name: 0.99.03.
    notes:
    - Move|region could crash if the selection contained Faces that only.
    Shared a single vertex (and not any edge). Now a proper error message.
    Is given. Same correction for the scale, rotate, and Flatten commands.
    Operating on Regions. (gracias todo optigon.) [Bjorng].
    Face mode área readout in the status bar would cause Wings todo Slow down if.
    The the face contained todo Many vértices. Wings now only calculates the Area.
    For a face with less than 50 vértices. (gracias todo jdcoke1.) [optigon].
    View|frame would symmetrically frame elements when using the virtual mirror.
    Now there is an option, view|frame disregards mirror, todo alter this behaviour.
    (gracias todo extrudeface and entity325.) [optigon].
    New feature: face|swep/swep region/swep extract. Swep is an interactive.
    Tol designed todo make angled extrusións, while a los allowing you todo scale.
    And rotate the extruded Regions simultaneously. [optigon].
    The plug-in manager could crash or fail todo provide información for.
    Certain (correctly written) plugins. (gracias todo optigon.) [Bjorng].
    New. German translation [contributed by torsten manz].
    New feature: edge|circularise. A plugin todo Flatten, equalise, and inflate an.
    Edge loop todo its máximum or user specified diameter. Basic and advanced menú.
    Options availble. [optigon].
    Now using erlang/otp r12b-3. [Bjorng]
    /pre>
    Saludos ala2.
    Administrador
    Ya se puede ir probando la versión 0.98.04 se (the special edition), una especie de beta con las novedades que traerá la próxima versión oficial.
    Descargas: Windows XP, Linux, Mac OSX.
    Wings-0.99.04-se: here a new build that includes everything in the current SVN branch. However, múltiple proxy subdivisión-levels has ben removed due todo bugs.
    Get it now: Windows XP, Linux, Mac OSX.
    Here another preview build of the next reléase with all of optigon Stuff..
    http://home.comcast.net/~chronosphere/Wings-plugins.htm
    experimental features:
    1. Left alt-clik todo select edge-loops. Right alt-click todo select edge-rings.
    2. OpenGL 2.0 Shaders and Yoda (in view menú).
    3. Anti-aliasing of Polygons/images/whole interfaz. (Mac and Linux only)
    committed features:
    - New feature: circularise now works on open Edge Loops, and by pressing 1
    During the drag phase of the tool, you can choose todo Flatten or not Flatten.
    The result todo a single plane. [optigon]
    - New feature: view|highlight aim, aims the Camera at the mouseover highlight.
    Which lets you aim the Camera while other geometry is selected. Options in.
    Edit|preferencias|advanced allow you todo specify targeting behaviour. Although.
    The original view|aim command remains, y have changed the Wings default.
    Hotkey a todo call highlight aim instead, on a fresh install. [optigon]
    - Repeating move|region in selection modes other than face caused Wings todo.
    Crash. Now fixed. [optigon]
    - Selecting every face of an object during a Vector op would crash Wings.
    - Partial rewrite of swep plugin todo improve the code including:
    - Vértices on sepárate objects sharing the same id number, would cause.
    Unexpected results. Vértices are now processed correctly.
    - Swep|free side todo side motion was reversed. Now fixed. (gracias todo getave)
    - Added relative mode todo swep commands.
    - Improvements todo processing speed.
    [optigon]
    - New utility tools|memory usage. Measures how much memory your current scene.
    Is using. (gracias todo giniu.) [optigon]
    - New colour prefs for the menú bar and info line backgrounds. [optigon]
    - Reorganized view menú. [optigon]
    - Deselecting with nothing selected would add an unnecessary undo state. Now.
    Fixed. (gracias todo giniu.) [optigon]
    - Lowered minimum undo level todo 1 (edit|preferencias|misc). [optigon]
    - Changed default Camera mode todo Wings 3d mode for fresh install. [optigon]
    - Made most of the defined hotkeys translatable. This a los affect commands.
    Displayed in edit|repeat and the plugin manager. [optigon]
    - New feature: Arc intersect. Allows you todo rotate a selection using a geometry.
    Specified angle. [optigon]
    - Disabled translation macros for save and open in Windows because they could.
    Cause Wings todo crash when displaying latin 5 characters in native dialogs.
    Furthermore, it is highly recommended that you do not save Wings files using.
    Accented or non-english character. (gracias todo devilgren.)[optigon].
  1. Blender 2.61 release y avances
    Por SHAZAM en el foro Noticias
    Respuestas: 64
    Último mensaje: 27-02-2012, 22:28
  2. Blender 2.60 release y avances
    Respuestas: 89
    Último mensaje: 14-12-2011, 21:29
  3. Wings3d 0 99 04 release
    Último mensaje: 11-10-2008, 04:33
  4. Wings3d 0 99 xx release y avances
    Respuestas: 27
    Último mensaje: 14-03-2008, 00:05
  5. Houdini 9 1 124 release y avances
    Respuestas: 25
    Último mensaje: 07-02-2008, 02:35
