    Aug 2007
    The gimp va tomando forma
    Gimp - Reléase notes for the 2.5 development snapshots. La biblioteca gegl va asomando la cabeza en Gimp, parece que vamos a ver cambios importantes para la 2.6.
    __________________________________________________ ______________.
    Gnu image manipulation programa.
    Development branch.
    This is the unstable development branch of Gimp. Here we are working.
    Towards the next stable release, which Will be Gimp 2.6.
    Changes in Gimp 2.5.0.
    Core:
    -Improved rectangle tool drawing for narrow mode.
    Ported Lots (but not all) drawing code todo Cairo.
    Optimized image rendering by using pre-multiplied alpha.
    Use new glib features such as gregex.
    Use new GTK+ features such as the new gtktoltip Api.
    Much improved gimpcurve object.
    Cleaner and smaller tool options.
    Enable brush scaling for the Smudge tool.
    Added debugging framework that can be enabled at run-time.
    Depend on gegl and use it optionally in some color operations.
    Optional gegl processing for all color tools.
    Add proper settings objects for all color tools.
    Add list of recently used settings todo all color tools.
    Added experimental gegl tool todo use arbitrary gegl operations.
    Event filtering and smoothing for better Paint tool performance.
    Added motion constraints in the move tool.
    Some operations do not any longer automátically add an Alpha Channel.
    Some preparation for tagging resource files.
    Cutting a selection doesnt clear the selection any longer.
    Added new polygon select tool.
    Load brushes and other data files recursively (search th rouge subdirs).
    Started work on lenguaje selector for the text tool (unfinished).
    Allow todo set opacity of the transform tool preview.
    Merged Toolbox menú into the image menú.
    Always kep an image window around.
    Improved image statusbar.
    Dropped documents in favor of ~/.recently-used.xbel.
    Started todo work on text box functionality in the text tool.
    Numerous bug fixes and cleanups.
    Plug-ins:
    -Dicom: improved handling of 16 bit image data.
    Ayuda: use gio todo Access the help index.
    Print: moved page setup out of the print dialog.
    Psd-load: rewritten, cleaner and more features.
    Randomize: added previews.
    Ripple: added a phase shift control.
    Screenshot: optionally add the mouse cursor image on an extra layer.
    Uri: use gio/gvfs where available.
    -Whirlpinch: allow a larger range for the whirl angle.
    Python Binding:
    -Allow todo specify colors using CS color names.
    Added new method image, new_layer().
    Script-fu:
    -Enforce r5rs syntax for let.
    Improved frosty logotipo script.
    Pdb:
    -Added new text layer Api.
    Added Gimp-vectors-export-to-file and Gimp-vectors-export-to-string.
    Added procedure todo test for existance of a procedure in the pdb.
    Improved error handling for procedures.
    Libraries:
    -Added some Cairo utilities.
    Allow todo use markup in toltips.
    Libgimpthumb doesnt any longer depend on other Gimp libraries.
    Miscellaneous:
    -Use the gimptol programa on Unix, to, instead of the gimptol script.
    Create the list of supported mime types at compile-time.
    Gimp shows library versións when called with -versión -verbose.
    Contributors:
    Sven neumann, Michael natterer, Martín nordholts, Bill skaggs.
    øyvind kolås, manish singh, Kevin cozens, alexia death, tor lillqvist.
    Marcus hese, John Marshall, joao s. O. Bueno, jakub steiner.
    Simon budig, Tom lechner, Hans Breuer.
    __________________________________________________ _____________. http://developer.Gimp.org/screenshots/Gimp-empty.png. Saludos.
    Nov 2007
    Muy buena noticia, al final desterraré Photoshop de mi PC. Un saludo.
    Ninja Fever
    Jun 2003
    A mí me gustaría saber para cuando va a saber cargar correctamente las transparencias de ciertos (*.tga), cuando traerá implementadas las carpetas para capas, cuando se podrán hacer transparencias de bordes interactivas (al estilo Corel PhotoPaint) y que es eso del gegl.
    Por todo lo demás, pinta bien. La semana que viene doy un tallercito de Gimp en la universidad, les avisaré de los cambios.
    Aug 2007
    Todo eso será posible una vez implementada la biblioteca gegl y Cairo para dibujar. Según he leído primero se migraran las herramientas, luego ira todo lo demás. Espero que esto marque el antes y después que necesitaba Gimp desde hace algún tiempo, elminando muchas restricciones que tenía y que a muchos nos ponían los pelos de punta. gegl-0.0.16 -> web de la biblioteca general de gráficos.
    Cairo (biblioteca) - Wikipedia, la enciclopedia libre -> en la Wikipedia sobre cario (muy interesante).
    cairographicsorg -> web de Cairo.
    Última edición por Bluder; 14-04-2008 a las 05:24
    Jul 2005
    Es verdad, si hay algo que me pone negro es lo tener que grabar en varios formatos antes de conseguir que Gimp abra un fichero como es debido.
    Si lo solucionan con la nueva librería, me doy con un canto. Suerte con los alumnos Mars, que ahora vienen de la logse.
    ...y estaba superbueno.
    Dos niñas en el parque
    no se elevará, nunca más
  1. Unir dos objetos una tomando la forma del otro
    Por liliani en el foro Modelado
    Último mensaje: 23-05-2011, 18:28
  2. Moncheta tomando el sol
    Por animator_3d en el foro Trabajos Finalizados
    Último mensaje: 10-04-2009, 12:29
  3. Tomando forma con partículas flow
    Por jesuslen17 en el foro Partículas y Dinámicas
    Último mensaje: 05-04-2009, 04:23
  4. Gimp FX Foundry 2 6-1-mas de 100 efectos nuevos para tus fotografías con GIMP
    Último mensaje: 06-03-2009, 20:10
