Página 1 de 14 12311 ... ÚltimoÚltimo
Resultados 1 al 10 de 133
    Administrador
    Animationmaster Hashs animation master 2006 v13-0 release y avances
    [b]ya esta lista la oficial Hash Animation Master 2006 v13.0 release. Que ganas de actualizar.
    Cita Iniciado por /b
    here are enlaces todo the v13.0 installer.
    Windows: v13.0 installer (2006 - Yeti CD). v13.0 network installer (hasp requires 2006 subscription).
    OSX (univeral binary): tigerinstall13.zip.
    Fixes.
    • 0003208: [installation (Intel)] invalid library Path on installation (gaijin)
    • 0003197: [_ not selected _] last light is now the ton light. Default choreography light order reversed for ton light todo look better. (noel)
    • 0003185: [rendering] jumsuit on girl in sci fi scene renders wrong (Steve)
    • 0003021: [plugins] unable todo load newtonphysics and symbiont2 plugins (alantruly)
    • 0003168: [rendering] simbionte is rendering wrong (Steve)
    • 0003039: [interface] toltips are blank (Steve)
    • 0002996: [hair] progressive rendering has artifiacts (alweb)
    • 0003073: [interface] FinalRender panel history section screwed up (Steve)
    • 0003192: [Voice-O-Matic] exercise 7 (James hash)
    • 0003195: [_ not selected _] Fog image now renders correctly in background when alpha buffer is of (noel)
    • 0003191: [interface] drag drop into chor now uses default poses results for surface collision. (kekat tail is posed above Ground in next CD) (noel)
    • 0003156: [net render] multipass render does not work in netrender (godfrey)
    • 0003162: [net render] netrender always renders with Alpha Channel on, cant change (ddustin)
    • 0003172: [_other] no names in community window (James hash)
    • 0003116: [_other] scifi cityscape on new hash2006 CD crashes on load (Steve)
    • 0003091: [rendering] Specular is wrong on Buzz helmet (Steve)
    • 0003135: [materials] combiner material does not work on the Mac (Steve)
    • 0003157: [net render] feature request: show each client frames rendered/average time in render server (godfrey)
    • 0003151: [realtime] exception #33 After opening a Project (Fred)
    the Hair Shaders mentioned in this thread are included in in this release.
    Examples prj todo play with: hair, prj and hair_oirg, prj (r-clik and select save-as)
    Administrador
    Primera actualización: a:m v13.0a.
    Cita Iniciado por
    Windows:
    [URL="http://www.s1.hashmirror.com/ftp/pub/updates/Windows/am2006/am2006. Exe"
    v13.0 installer[/url] (2006 - Yeti CD) (11m). v13.0 network installer (hasp requires 2006 subscription) (15mb)
    reference.exe f1 help file installer (51mb)
    OSX (univeral binary): tigerinstall13.zip (23m).
    Fixes.
    • 0003252: [hair] Wild Hair in NR (dylanperry)
    • 0003242: [hair] Hair problems (rkaneko)
    • 0003198: [rendering] render hangs (pianoman)
    • 0003269: [materials] plugins missing text string for sub properties of color and vector2 (scale) (tarmer1)
    • 0003244: [interface] values text in properties panel is white (jandals)
    • 0003177: [hair] two: Hair-position variation does not vary position (jandals)
    • 0003250: [composite] chors dont save with frameburn (noel)
    • 0003243: [_ not selected _] changing model color over time (Heath)
    • 0003245: [plugins] projects for two saved with SimCloth look up when re-opening. (mz_timelord)
    • 0003196: [rendering] m_usefrontrealtimelight not exposed or inited (noel)
    • 0003083: [SDK] call for checking the state of object render mode for a model in the chor (sgross)
    • 0003220: [animation] two: when face nulls reach límites keyframes are still efected. (kenh)
    • 0003047: [rendering] error loading string 5886 (Jak west)
    • 0003227: [materials] extended gridturbulance combiner causes error when the material root is deleted (splinesmith)
    • 0001312: [animation] force keyframe button adds keys for Bones not in current choreography action (jandals)
    • 0003234: [relationships/poses] force keyframe does not create keys in a pose. (bobcroucher)
    • 0002564: [_other] compensate mode + force keyframe not resetting Bones/nulls (robcat2075)
    • 0002926: [animation] null refresh issue when you use compensate/force keyframe. (kenh)
    • 0003176: [interface] displaying rulers for exercise 5 (James hash)
    • 0003229: [net render] crash on job-wizard if no io plugins loaded (willp)
    • 0003214: [SDK] added SDK addnullobjectcache (sgross)
    • 0002543: [SDK] open/save/dirrequest calls in plugins fixed. Wraped with scope {} around afx_manage_state (afxgetappmodulestate ()), then call; (sgross)
    • 0003209: [rendering] cant render todo file when Camera has plugin shader, and tools options rendering is using settings form the Camera (fmsonic)
    Examples prj todo play with: hair.prj and hair_oirg.prj (r-clik and select save-as).
    Saludos actualiza2.
    Administrador
    Llega la b.
    here are enlaces todo the v13.0b installer.
    Windows:
    -fixes.
    • 0003297: [interface] customize interface color doesnt work as expected (tartiflette)
    • 0002165: [animation] can now export Camera chor action, and use on another Camera (gschumsky)
    • 0003013: [interface] universal- Ghosted (inactive) icon bitmaps do not show on toolbars (Steve)
    • 0003311: [materials] altering decal images in Photoshop crashes a:m when it regains focus (Paul forwod)
    • 0003284: [_other] Mac sabes full file Path beginning with drive name (jandals)
    • 0003296: [interface] the SimCloth and newton setting for the choreography are missing (splinesmith)
    • 0003133: [animation] visibility animation track does not change over time (obsidian games)
    ¿Qué pocos fixes, ¿no? Buena señal.
    ¿Sabíais que el plugin de exportación a flash de zpider viene ahora integrado de paquete?
    Pues yo me acabo de enterar. Saludos actualiza2.
    Eso se arregla en pospo..
    Apr 2003
    ¿Sabíais que el plugin de exportación a flash de zpider viene ahora integrado de paquete? Pues yo me acabo de enterar.
    Ole.
    Administrador
    a:m v13.0c.
    Cita Iniciado por
    Windows:
    [list
    [*]v13.0 installer (2006 - Yeti CD) (11m)[*]v13.0 network installer (hasp requires 2006 subscription) (15mb)[*]v13.0 nethasp network installer only install if you are using a multiseat network hasp (nethasp requires 2006 subscription) (15mb)[*]reference.exe f1 help file installer (51mb)[/list]OSX (univeral binary):
    -fixes.
    • 0002925: [composite] lightbuffers 4 pass makes a black.exr (eric2575)
    • 0003381: [plugins] selectanddatapropertysample (noel)
    • 0003338: [interface] editing Fields in manipulator properties panel often leads todo crashing (Stuart Rogers)
    • 0003370: [materials] crash when entering values in the advanced manipulator (Barney)
    • 0003371: [timeline/channel] zero undo levels causes a:m todo crash todo desktop (mz_timelord)
    • 0003383: [_ not selected _] v12 pws filters with types, dont load and cause window placements todo be Skipped on load. (noel)
    • 0002903: [SDK] some issues with hfilenameproperty (sgross)
    • 0003356: [net render] EXR light buffers not working (Jak west)
    • 0002892: [realtime] model shortcuts in bound draw mode would cause an exception when a choreography loaded in muscle modeling or distort mode. (Steve)
    • 0003275: [realtime] groming in a choreography would crash if you didnt have a model shortcut selected. (ddustin)
    • 0002277: [composite] net render no light buffers for composit (Jak west)
    • 0000792: [net render] the scene that applies posteffects(postplugin) is not correct in netrender. (fb_o)
    • 0003368: [composite] when a mensaje effect is the focus of the composite view its changes are updated correctly now. (noel)
    • 0003367: [rendering] scaling a Sun light in chor increases light intensity dramátically (yves)
    • 0003291: [hair] exception #035 load Hair model (jenpy)
    • 0003290: [hair] the Hair collision does not work (jenpy)
    • 0003345: [_other] constant drivers loaded incorrectly (jenpy)
    • 0003343: [net render] re ordering jobs in render server (dylanperry)
    • 0003203: [_other] some expressions caused close, revert or open Project todo fail (ddustin)
    Tresmiltornillero
    0003291: [hair] exception #035 load Hair model (jenpy) ese error me salía al cargar a Harold, un actor de la biblioteca. Un abrazo, updating.
    Administrador
    V13.0d.
    Cita Iniciado por
    Windows:
    [list
    -fixes.
    • 0003437: [_ not selected _] hooks shouldnt save position or bias información, causes SVN conflicts. (two) (bobcroucher)
    • 0003436: [_ not selected _] locate files dialog should remember relative paths for locating future files. (bobcroucher)
    • 0003423: [hair] Hair Shaders are changing the rendering on non-hair objects (cosmonaut)
    • 0003393: [plugins] consolidate works with any filename property, for dark tres etc. (noel)
    • 0003342: [_other] cannot load choreog into choreog without crashing (dylanperry)
    • 0003424: [net render] ability todo launch vnc or other remote view software from node in renderserver (willp)
    • 0003233: [animation] two: changing blend mode of action in chor messes up blending. (kenh)
    • 0003403: [modeling] finding patches in wireframe mode when modeling (noel)
    Administrador
    Como somos pocos a:meros dejo esta noticia aquí, para no abrir hilos solitarios. Los de enhance:a:m textures están de rebajas y me pareció oportuno anunciarlo, por si a alguien le interesa, hay materiales muy chulos. http://www.Shaders.co.uk/enhance:am/. Saludos, texturiza2.
    Tresmiltornillero
    Me gusta ser de los pocos que del montón. Es más friki. Gracias por la noticia.
    Administrador
    En hash no paran. La 13:0e.
    Cita Iniciado por
    Windows:
    [list
    -fixes.
    • 0003448: [relationships/poses] bone relationships created in versión c do not work in versión d (rwilliamson)
    • 0003458: [animation] cp weighting problem when cp controlled by the same bone more than once. (kattkieru)
    • 0003372: [rendering] am crashes when rendering with animated surfaces. (rkaneko)
    • 0003441: [decaling] continued problem of crashing when rendering todo file - Movie or image sequence only (Mike b.)
    • 0003450: [modeling] #001 crash After making a hok (kenh)
    • 0003454: [materials] annoying visual Glitch with models that have emmitter materiales (raillard)
    • 0003411: [decaling] #001 unhandled exception crash in postura Windows. (kenh)
    • 0003414: [relationships/poses] unhandled exception #001 with specific model/action (emilio le roux)
    • 0003390: [constraints] compensate mode does not work on a pair of crucial Bones (raillard)
    • 0003387: [materials] normal tweak material nodes had no effect when material, Bump Percent was set (Jak west)
    • 0003351: [plugins] properties are not correct saved (sgross)
  1. Blender 2.64 release y avances
    Por SHAZAM en el foro Noticias
    Respuestas: 24
    Último mensaje: 11-12-2012, 10:51
  2. Respuestas: 50
    Último mensaje: 24-11-2007, 22:03
  3. Hashs animation master 2006 v14 0 alpha
    Último mensaje: 03-10-2006, 15:37
  4. Respuestas: 128
    Último mensaje: 04-07-2006, 12:09
  5. Hashs Animation:Master v12 saldra el 05 de julio
    Último mensaje: 01-07-2005, 23:31
