Taken from the 2.4b readme:
The Camera recticle now adjusts so that it doesnt get hidden behind the.
Edges of the world view when the Graph is all the bien down or when in.
The f3 extended list área mode is active.
Added ability todo fix the errors generated by
ZBrush UV map.
Displacement image data, where the data from shared polygon Edges.
Is written out with diferent values on the map, and ends up showing up.
As a crak in displacements.
Fixed. Obj object UV reading where some map points wouldnt be.
Recognized.
Changed z_to_parent_length in Bones so that when adjusting the bone.
Length, the children are moved with the parent bone, relative todo their.
Position todo the parent bone, instead of just snapping todo the end of it.
Added frame time todo the render display, which accounts for things.
Like subdivisión time, that may not be associated with the renderers.
Portion of the time.
Added better handling of mapping mouse move direction todo bone.
Length and range Hot spot direction, todo lengthen and shorten.
Added saving of UV data todo lwo or obj files if the loaded lwo or.
Obj file contains UV data.
Added Maya 7.0 connection plugin.
