Tema: Wings3d v0 98 32
    Administrador
    Wings3d Wings3d v0-98-32
    Suculenta versión recién salida del horno, interesantes implementaciones relacionadas con Yafray. Copio y pego.
    Reléase name: 0.98.32
    Notes:
    - New settings todo work-around invisible Edge problems in (edit|preferencias;
    Tab Misc, bottom of dialog box). If you have problems with disappearing.
    Edges, try higher values in the two Fields. (to high values Will cause.
    Other problems, so it is best todo increase the values gradually.) please.
    Mensaje the results in the forum. (by dan.)
    - The pre-built Wings packages now use erlang/otp r10b-7.
    - Fixed a bug that made it posible todo turn on magnets for commands that were not.
    Supposed todo take magnets, in most cases causing a crasch.
    (e.g, activating the extrude command by Alt+mb clicking.)
    (problem reported by getave.)
    - The file dialog for Linux (and optionally Macintosh) is now translatable.
    And has ben translated todo polish. (by giniu.)
    - New Tesselate|untriangulate command. (by trepan.)
    - The Edge loop command is now estoppable, for instance, if two Edges are.
    Selected, the command Will select only the Edges between them (going the.
    Shortest way). Same for Edge ring. (by dan.)
    Autouv/Snap (by dan):
    - Cylinder and sphere mapping work better in some cases (if Cut properly).
    - Miscellanous bug fixes in move/scale in Snap image.
    Yafray/Toxic (by raimo):
    - Moved os job and rendering job functionality out from wpc_yafray and.
    Wpc_toxic todo the new module wings_job, todo facilitate more rendering.
    Plugins. There are new preferencias in the user interface tab of.
    Edit|preferencias.
    - Yafray: added, HDR rendering output file format.
    Restructured the render/export dialog and implemented the a_jitterfirst, clamp_rgb, alpha_premultiply, and alpha_backgroundmasque settings.
    Implemented the new depth-of-field parameters. Removed the already.
    Defunct antinoise filter.
    Implemented Occlusion mode for pathlight, and maxdistance parameter.
    For pathlight and Hemi Light.
    Corrected a bug reported by oort: when using EXR output format.exr filename sufix was not default.
    Added material dispersión.
    Added spherelights.
    Added visible lights (for point, software- And spherelights).
    Moved output format parameters todo plugin preferencias, and introduced.
    A possibility todo use an external viewer todo view e.exr files After.
    Rendering.
    Added absorption parameters todo the generic shader.
    Added.exr output file format support.
    Added new Camera types ligthprobé and Spherical.
    Added Subsurface Scattering block shader. Oh, and i forgot, last.
    Versión i added a checkbox for keping the intermediate.xml file.
    When rendering.
    Added, HDR rendering output file format for wpc_yafray.
    saludos ala2,
    Shazam..
    Victor Navone
    Chuck Jones
    John Lasseter
    BlenderAdicto
    Jun 2002
    Wings3d v0-98-32
    Gracias Shazam. Parece que han añadido muchas mejoras en la comunicación con Yafray, eso me recuerda que todavía no he probado la salida a OpenEXR, más deberes. Saludos.
    Grafosyakuza
    Wings3d Wings3d v0-98-32a
    Y ya tenemos en el horno la v0.98.32a. Esto es lo que pasa con las betas.
    Reléase name: 0.98.32a. Notes:
    -Should now work on Mac os 10.3.x (Panther).
    Yafray: raimo fixed the save and load buttons in the render/export dialog. (problem reported by ort).
    The french translation has ben updated by syndarion.
    The czech translation has ben updated by libor divis.
    The mouse has ben speded up in interactive commands when a constraint key is held down. (by dan).
    Internal change by giniu: separated compile time functions and translation tools from main source.
  1. Wings3d 0 99 06
    Por SHAZAM en el foro Noticias
    Último mensaje: 10-11-2008, 00:14
  2. Wings3d 0 99 04 release
    Último mensaje: 11-10-2008, 04:33
  3. Selección en Wings3d
    Por fmelian en el foro Modelado
    Último mensaje: 23-10-2006, 18:33
  4. Wings3d v0 98 34
    Último mensaje: 08-08-2006, 19:38
  5. Wings3d v0 98 35
    Último mensaje: 23-07-2006, 15:03
