Aqué están los fixes y añadidos:
Testeando.Iniciado por /Wings3d
Dan fixed (hopefully finally) the rotate commands speed so they work as before.
Dan fixed rotate in vertex mode so it centers around all selected vértices.
Giniu made all active (compilable) plugins translatable and translated them todo polish.
(the Toxic and Yafray plugins still neds todo be translated, but are translatable).
Giniu added 4 selection methods: select by vértices with 6 or more Edges, select by non quadrangle Faces (all Faces, Faces with ODD or Even number of Edges).
Giniu added two new tools - Move->absolute for positioning in absolute.
Coordinates and weld for welding single vertex todo other one.
Desiredusername/microbesoft implemented pick-up and drop images in outliner.
Syndarion updated the french translation.
Autouv changes (dan):
- In Face Mode added a combined Project from normal and unfolding command.
- In segmenting mode, when uv-mapping failes the god charts gets uv-mapped and.
The failed charts stays in the segmenting window.
- Mb on uv-mapping, finds and Marks the old chart cuts.
- Repeat implemented.
- Other minor Stuff, uv-grid and changed material/image handling.
- Re-written the texture image creator, move images with your UV or.
Use it todo draw vertex color or materiales it can a los use OpenGL Shaders.
Programmers:
Update todo the latest erlang release. (png requires it)
Both the #we and #st have a new field pst (plugin state)
That requires a re-compilation of most (allí) of the external plugins, plugins that use the pst field should export two functions:
Plugin:merge_we ([we1,we2.]) and plugin:merge_st(newdata,oldst) both should.
Return the new data of the plugin.
Citar
