Resultados 1 al 10 de 26
Tema: Tormenta de ideas para la Gui de Gimp
    Ninja Fever
    Jun 2003
    Tormenta de ideas para la gui de gimp
    Gimp UI brainestorm: fullscreen + transparency….
    got ideasí.
    This is a visual brainestorm, the channel for a todo el mundo todo contribute todo the Gimp UI redesign process. It is moderated by the Gimp UI redesign team we do not mensaje mock-ups here ourselves, we listen todo what you show us and broaden our horizons.
    To kep things easygoing + fun around here, there are some rules:
    Explain your idea in an image or two. Only these images Will be published, so make sure any neded explanation is inside them. Images must be in (*.jpg), gif, bmp or (*.png) format, máximum 8 Mb each.
    Your images should show your idea in a clear way, but they dont have todo be Glossy and polished. Plain Vector drawings or Even scanned Pencil sketches should a los work.
    Send your image to us, put the Word Gimp in the title of your email (to avoid spam, emails without Gimp in the title or without an image attachment Will not be opened).
    We Will not publish your name or email address, if you want todo be identified with--or Even contacted about--your contribution, place your name or email address discreetely in your image.
    All further text you place in your image can only be used todo explain your own idea. Kep it short, point out what is innovative. If you fel you ned a lot of text todo explain, then maybe your idea is not working on an user interaction level.
    Do not write in your image about other people, other peoples ideas or why Gimp sucks, because.
    Polemic kills brainestorming, hence there are not going todo be discussions or comentarios in this blog. If you want todo vent, use the usual channels. If you have got a better idea, Simply show it todo us.
    If you want todo respond todo a contribution, by all means take the image, modify it with your own ideas for improvement and send it bak todo the brainestorm. Visual dialogue: it is allowed and encouraged by the c licence on this blog.
    We are pretty liberal europeans, but anything obnoxious Will ensure that your image does not get published here. We Will not modify your image in any way, so either it is fit todo be blogged or it Will be discarded.
    Our team Will label your contribution and sometimes we Will write a few sentences of Analysis, if we are not todo busy working on Gimp.
    Your contribution has todo be compatible with the license of this blog. Speaquíng of.
    Tresmiltornillero
    Como tan parado está el Gimp desde hace tiempo, aunque se haya ido desarrollando por detrás, pero nada de compilaciones.
    Me he pasado al Paint, net que es freeware, pero que avanza de verdad.
    Usuario completo
    Aug 2007
    Madre tiene pinta de ser cómodo trabajar así, uf esos botones de abajo son todo un detalle. Me encantaría pintar ahí.
Nombre: gimp-transparent-fullscreen.png
Visitas: 1175
Tamaño: 868.3 KB
    Última edición por 3dpoder; 12-04-2008 a las 15:32
    Administrador
    Mi idea para Gimp: que se parezca lo máximo posible a Adobe Photoshop.
    Victor Navone
    Chuck Jones
    John Lasseter
    Usuario completo
    Aug 2007
    Hay algunas que están muy bien. Gimp UI brainestorm: Windows in window.
    Blendemoniado
    Mar 2006
    Vaya pedazo de interfaz, así da gusto la verdad es que estaba deseando. Estoy deseando pillarla. ¿Esta ya disponible?
    Usuario completo
    Aug 2007
    Supongo que no, son conceptos, eso creo vamos.
    Mi mensaje número 100.
    Blendemoniado
    Mar 2006
    Lo suyo sería que fuese customizable ¿no? Y así cada uno se la hace a su gusto. Con un deslizador para transparencia por supuesto.
    Enhorabuena por tu pst número 100 antes de que te des cuenta levaras un cero más.
    Usuario completo
    Aug 2007
    Personalmente no me gusta nada el hecho de que las ventanas independientes, cuando trabajo en patanlla completa, que lo hago mucho, tengo que andar alt-tab a ver si atino con la ventana correcta (lo cual no sucede casi nunca) para hacer cambios de tamaño, color, que haces cada 2x3. Y eso que en Linux nos beneficiamos de poder aparcarlo al un 2º escritorio y así poder abrir alguna aplicación más, en Windows no me quiero imaginar como seria. Saludos y ojalá lo metan todo dentro de la misma ventana, no sé qué ventajas tienen las múltiples ventanas, especialmente con monitores no muy grandes.
    Posdata: Gekonidae ya le he pedido otro 0 a los reyes.
    Jan 2004
    Vaya que pedazo de programa si lo ponen así.
    Obsesionado por la calidad
  1. Ideas para decorar
    Por Jypena en el foro Todo menos Infografía
    Último mensaje: 03-01-2019, 13:22
  2. Ideas para una historia
    Por Nacho47 en el foro Storyboards
    Último mensaje: 20-11-2009, 04:09
  3. Gimp FX Foundry 2 6-1-mas de 100 efectos nuevos para tus fotografías con GIMP
    Por 3dpoder en el foro Programas de Diseño gráfico y CAD
    Último mensaje: 06-03-2009, 20:10
  4. Ideas para logotipo
    Por Gepetto en el foro Trabajos en Proceso
    Respuestas: 22
    Último mensaje: 09-06-2006, 21:46
  5. Ideas para un corto
    Por TheOutsider en el foro Peticiones y Búsquedas
    Último mensaje: 28-05-2004, 19:10
