Tema: Shortcuts para 3ds Max
    Shortcuts para 3dsmax
    No sabía bien donde colocar este tema, si no es aquí que un administrador lo mueva, espero que les sirva, saludos. Funciones de teclado de 3d Studio Max 5.
    Bueno, son para 3dsMax 5, algunas funciones trabajan para 3dsMax 6.
    Comando=teclado.
    Help = f1.
    Shade selected Faces = f2.
    Wireframe/ Smooth + highlights= f3.
    View edged Faces = f4.
    Restrict todo x = f5.
    Restrict todo y = f6.
    Restrict todo z = f7.
    Restrict place cycle= f8.
    Render last= f9.
    [b]render scene= f10.
    Maxscript Listener= f11.
    Transform type-in dialog= f12.
    Redraw all views= ` (~).
    Sub-object level 1= 1.
    Sub-object level 2= 2.
    Sub-object level 3= 3.
    Sub-object level 4= 4.
    Spot/directional light view= shift+4.
    Sub-object level 5= 5.
    Show main toolbar= alt-6.
    Polygon counter= 7.
    Environment dialog= 8.
    Render todo texture= 0.
    Lok user interfaz= Alt+0.
    Transform gizmo size down= menos -.
    Transform gizmo size up= más +.
    Top view= te.
    Show tab panel= y.
    Redo viewport operación = shift+y.
    Redo scene operation= Control + y.
    Isometric user view= u.
    Pan viewport= i.
    Spacing tool= shift+i.
    Select invert= Control + i.
    Adaptive degradation= o.
    Open file= Control + o.
    Perspective user view= p.
    Hide particle systems= shift+p.
    Pan view= Control + p.
    Cap (poly)= Alt+p.
    Zom viewport in= [.
    Zom viewport out= ].
    Sound=
    Set key mode=.
    Angle Snap= a.
    Select all= Control + a.
    Align= Alt+a.
    Snap= s.
    Hide shapes= Control + s.
    Save file= Control + s.
    Snap cycle= Alt+s.
    Zom extents selected all= z.
    Undo viewport operation= Shift + Z.
    Undo scene operation= Control + z.
    Zom mode= Alt+z.
    Transform gizmo= x.
    Expert mode= Control + x.
    Se-th rouge display= Alt+x.
    Disable viewport= de.
    Select none= Control + d.
    Front view= f.
    Show safeframes= shift+f.
    Cycle selection method= Control+F.
    Camera view= c.
    Hide cameras= shift+c.
    Match Camera todo view= Control + c.
    Cut (poly)= Alt+c.
    Clone Control + v=
    Hide grinds= g.
    Hide geometry= shift+g.
    Select-by-name dialog= h.
    Hide helpers= shift+h.
    Place highlights= Control + h.
    Bottom view= b.
    Sub-object selection= Control + b.
    Viewport background= Alt+b.
    Autokey mode= n.
    New scene= Control + N.
    Normal align= Alt+n.
    Show selection bracket=.
    Set keys= que.
    Material editor= m.
    Meshsmooth (poly)= Control + m.
    Left view= l.
    Hide lights= shift+l.
    Default lighting= Control + l.
    Backup time one unit=, (coma).
    Forward time one unit=. (punto).
    Play animation= /.
    Selection Lock= spacebar.
    Go todo start frame= home.
    Sub-object level cycle= replace.
    Select anc estor= page up.
    Select child= page down.
    Go todo end frame= end.
    Virtual viewport= Numpad /.
    Virtual viewport zoom in= numpda +.
    Virtual viewport zon out= Numpad -.
    Virtual viewport pan up= 7 8 9.
    Virtual viewport pan left= Numpad 4.
    Virtual viewport pan right= Numpad 6.
    Virtual viewport pan down= Numpad 2. Saludos.
    Posdata: por ahí lo pueden imprimir y pegar frente a su PC.
    Última edición por carlosall; 13-06-2005 a las 14:59
    Wiki Member
    May 2004
    Muy practico este mensaje, me viene de genial. Un saludo.
    Gracias tío muy practico.
    Supongo que ha nadie le ha picado la curiosidad que cuando se arranca el 3ds Max salen unos ejemplitos de las teclas. En la carpeta raíz hay un archivo que se llama splash, swf dónde está todo eso y más.
    Apr 2008
    Muchas gracias, me ha servido de verdad. Es cosa de ser un poco más intruso y descubrirlo todo del 3dsMax. I. Gracias.
  1. Blender Blender 2.8 keyboard shortcuts atajos de teclado
    Por yamikace en el foro Modelado
    Último mensaje: 08-09-2019, 17:46
  2. Maya Problema con Maya shortcuts
    Por kesioo en el foro Problemas con Programas
    Último mensaje: 26-03-2011, 16:49
  3. Jpeg con los shortcuts en el teclado
    Por rushdie en el foro 3DStudio Max
    Último mensaje: 08-12-2006, 13:50
  4. Shortcuts a scripts en 3ds Max consulta
    Por dfx3 en el foro Plugins
    Último mensaje: 14-03-2006, 17:42
