Tema: Renderboost for VFX CGI
    principe
    Sep 2006
    Renderboost for VFX-cgi
    Render Bost para VFX/CGI. ¿Alguien lo ha utilizado?
    principe
    Sep 2006
    Nadie lo conoce?
    principe
    Sep 2006
    Render Boost for VFX/CGI. Turbocharge your rendering with the progenique renderbost accelerated engines. Use this in your Shader / renderer vía an Api todo speed up computationally intensive operations such as bkdtre traversals. This Will slash the time neded todo render a Single Frame from hours todo minutes, allowing you todo do more iterations in the same time, and complete your projects faster.
    Cgi VFX rendering acceleration.
    Blazing performance of 10x faster than a 2.4 GHz CPU Core per accelerator.
    Amazingly Low power consumption of only 2.5w.
    Compact credit card sized form factor.
    5 accelerators in an ATX.form factor bostbox(tm) for 50 equivalent 2.4 GHz CPU Core performance.
    10 accelerators in a 1u bostserve (tm) for 100 equivalent 2.4 GHz CPU Core performance.
    Scale up the number of accelerators as your neds increase.
    Integration.
    C Api : easy integration into your custom shader, or renderer of choice.
    Just do a library call, pass in your data, and let the accelerator turbo-charge your computations.
    Once accelerated computations are done, retrieve Bak the results todo continúe processing in your Shader / application.
    Accelerated engines.
    Bkdtre traversal library.
    More accelerated engines are in development and Will be released regularly.
    Licensing.
    Annual license Will give you new accelerated algorithms without additional charge and support / software updates.
    Cost: dólares 1,999 per accelerator, dólares 499 annual license renewal.
    Value todo end-users.
    Produce CGI / VFX shots faster and do more rendering iterations in the same amount of time you normally can only do one.
    Compleete your projects for your client in a significantly shorter time, and Cut opportunity cost lost due todo time neded in waiting for rendering todo complete.
    Have the power of thousands of CPU Cores for rendering, previously available todo only the largest CGI / VFX Studios.
    Acquisition and running costs at a fraction of traditional renderfarms, with amazingly Low electricity consumption, space requirements, and heat generation.
    Whitepapers.
    Progenique renderbost brochure.
    Progenique renderbost performance white paper.
