Tema: Nueva versión Vray 1 47 02
    Mar 2003
    Nueva versión Vray 1-47-02
    Tengo muchas ganas de probarla. Pongo aquí las mejoras, solucionan ya al parece el problema con el pelo de max 7.5. Build 1.47.02 - 11 may 2005:
    Modified features:
    * Vray proxy objects are now treated as bitmaps so that they can be exported along with the rest of the scene.
    * if the secondary rays bias is 0.0 in texture baking mode, Vray Will automátically adjust this todo 0.001 todo avoid errors.
    Extended features:
    * new parameter Anisotropy added todo the Dof parameters. This allows the stretching of the bokeh effect horizontally or vertically.
    * added a hidden parameter system_vraylog_cctodebugger todo allow redirecting the Vray log todo the 3ds Max log file.
    * added a hidden parameter system_vraylog_numthreads for manual control of the number of rendering hilos.
    * added a new parameter blur GI todo the Irradiance Map parameters with the purpose of reducing flickering of GI in animations with moving objects.
    Bug fixes:
    * Hair in 3ds Max 7.5 in buffer mode did not render in Camera views.
    * complex materiales (blend, Shellac) and the fallof map with shadow/light mode did not work in Path tracing mode.
    * highlights were not computed in the progressive Path tracing mode of the Light Cache.
    * zoming and panning in the 3ds Max VFB could crash 3ds Max.
    * multi/sub materiales with some Shader types could render with wrong brightness.
    * interpolated Glossy reflections didnt work with multi/sub material.
    * crashes with displacement and Motion Blur when the displacement map used object XYZ mapping.
    * crashes during building the Irradiance Map with overlapped lok-up mode when interp, samples not divisible by 4.
    * when the override mtl button is clicked, the material browse dialog is opened twice in 3ds Max 7.
    * in Track View, the parameter names for Vray displacement mod were wrong.
    * the hilbert curve Generator crashed if the región size is larger than the rendered región.
    * rare crashes with dynamic geometry (displacement etc) when it neded todo be unloaded from memory.
    * objects with visible todo Camera of were visible in the z-buffer.
    * spots with back-facing UVW triangles in texture baking mode.
    * planar from object XYZ mapping mode did not work with Motion Blur enabled.
    * the ward brdf in the vraymtl could cause red dots in the scene.
    * missing UVW coordinates could cause splotches in the scene.
    * the Vray HDRI map with angular mapping type could produce invalid colors.
    * crashes with subdivisión/displacement when they were applied todo both moving and static objects in a scene with Motion Blur on.
    * the texture channel for Anisotropy was not working.
    * when switch todo saved map is on, Vray switched todo from file mode Even when GI is of.
    Jun 2002
    Ya han sacado la 1.47.03. ¿Qué rápido ¿eh? Lo único que cambia es. Bug fixes. Multi/subobject materiales caused increased CPU usage and/or crashes in the material editor. Saludos.
    La ley de Murphy es la ley que rige nuestros destinos...
    Yo la estoy testeando y desde que la licencia es por el Vray server se vive cayendo, es muy inestable.
    lodon...
    Ya te digo lo estoy sufriendo en carnes.uf, y si es un material multiobjeto con RayTrace no te digo nada, te dice.chato, que me cierro.
  1. Respuestas: 0
    Último mensaje: 13-09-2010, 11:16
  2. Discusiones generales Nueva versión
    Por D&D en el foro Discusiones generales
    Último mensaje: 01-02-2009, 15:27
  3. Nueva versión Vray 1 60
    Por minmax en el foro Noticias
    Respuestas: 134
    Último mensaje: 04-12-2008, 19:42
  4. Nueva versión de 3ds Max
    Por mesh en el foro Todo menos Infografía
    Respuestas: 33
    Último mensaje: 29-06-2005, 01:59
  5. Nueva versión Blender 2 35
    Por PERIK en el foro Infografía General
    Último mensaje: 23-11-2004, 09:48
