Wings3d nueva versión 0 98 36
    Wings3d Wings3d : nueva versión : 0-98-36
    Pues eso, ya tenemos nueva versión de este programa de modelado (open source de coste: 0 EUR). Descarga y más información en:
    www.Wings3d.com.
    Reléase notes:
    Or the first time, the Mac versión is a univeral binary that Will run on both Power PC and Intel Mac.
    Enjoy.
    /bjorn.
    Absolute Snap now can pik reference point, old Snap that used center of.
    Selection as reference point was moved todo Mb option. [giniu].
    Added new preference: constraint axes todo grid. [scorpius].
    Added blue Cube interfaz icons. The original icons are in the classic.
    Bundle. Switching between icon sets is easily accomplished th rouge the.
    User interface preference tab. [scorpius].
    Revived the plane plugin, which was removed from a previous release.
    Because it created invalid objects. This has ben fixed by adding a.
    Thickness parameter, thereby creating a properly closed Mesh. [scorpius].
    Added two new primitives (lok under the more menú):
    Tube: generates a hollow tuve or pipe with an actual wall-thickness, gear: generates a very simple gear. Allows the user todo specify the number.
    Of teth and the toth height. [scorpius].
    Added two more primitives:
    Ncube: generates a Cube with an arbitrary level of subdivisions (Simply.
    Specify the number of cuts per edge) plus a spherize option, Ngon: generates a polygon with an arbitrary number of vértices. This may.
    Lok like a single-sided polygon but, in fact, has two Faces. [scorpius].
    New geodome primitive. Generates a geodesic dome with an arbitrary level.
    Of subdivisions. Has thre base objects, spherize and half-dome options.
    [scorpius].
    New *.stl import/export plugin. Stereolithography files can be sent todo.
    A service bureau todo create an actual Plastic Prototype of your model.
    [scorpius].
    New command in tools menú: scene información: área & volume. Calculates the.
    Area and volume for each object in the scene and displays the información in.
    A pop-up window. [scorpius].
    Bug fix: language support now works for all operating systems, regardless.
    If the file Path has an underscore. [scorpius].
    Added x export plugin.
    [contributed by ed kolis (ekolis)].
    New command in tools menú: put on Ground. It Simply moves the selected.
    Objects vertically until they rest on the Ground plane. [scorpius].
    Added Purple tuve interfaz icons. Chek the user interface preference.
    Tab todo switch between icon sets. [scorpius].
    New commands in select->by menú: fewest Edges Path selects a Path.
    (between any two selected vértices) with the fewest number of Edges.
    Shortest Path selects a Path with the shortest distance. If more than one.
    Posible solution exists, the first one found Will be selected. [scorpius].
    New secondary mode for dissolve, called clean dissolve.
    [contributed by Richard Jones (optigon)].
    Added ability todo set alternate zoom speed, chek Camera preferencias.
    Tweak tool extended with new features like Tangent, relax, slide and more.
    [contributed by Andrew shpagin (andrewshpagin)].
    French translation updated, with Many more plugins translated.
    [contributed by Nicolás bouillard (syndarion)].
    The Mac versión of Wings is now a universal binary that runs on both.
    Powerpc and Intel Mac. [Bjorng].
    The Windows versión now includes the correct (latest) versión of the.
    SDL dll, correcting numerous problems. [Bjorng]. Saludos, modeala2.
    Nov 2005
    Gracias Shazam.
    "¡No! no lo intentes. Hazlo o no lo hagas, pero no lo intentes." - Maestro Yoda
    Malditos sean. 3 meses que no actualizan, comienzo el curso y ya me cambian la versión para que me de petios y diferencian en los menús.
    Al menos sabemos que no se ha muerto el proyecto.
    Por cierto, casi todas las updates son de scorpius, bien por él.
  1. Wings3d 1 4 nueva versión
    Por themonster en el foro Noticias 3D
    : 28-01-2011, 22:37
  2. Nueva versión
    Por D&D en el foro Noticias 3D
    : 01-02-2009, 14:27
  3. Nueva versión de Fryrender
    Por Reaversword en el foro Noticias 3D
    : 14-07-2008, 19:43
  4. Ciencia y curiosidades Nueva versión de 3ds Max
    Por mesh en el foro Ciencia y curiosidades
    Respuestas: 33
    : 29-06-2005, 00:59
  5. Wings3d 0 98 31 nueva versión
    : 28-06-2005, 14:04
