Synfig Studio open-source animation software
    Aug 2006
    Thumbs up Synfig Studio open-source animation software
    Os paso un software para la animación en 2D, es de código abierto y gratuito.
    Features:
    Spatial resolution-independence Most elements are vector-based, and all layers are parametrically generated, hence even when changing the target resolution of a project, the only pixelation will occur in imported raster images, not the built-in components.
    Temporal resolution independence
    Animation-keyframes are automátically interpolated by the computer, resulting in Smooth motion
    High Dynamic-Range Imaging (HDRI) By using floating-point math in the image calculations, HDRI processing allows canvases to internally understand a far greater range of píxel luminance, resulting in better lighting effects, and improved color composition.
    Pentablet-friendly tols
    The draw tol already reads the pressure sensitivity channel of your favorite tablets, for natural line weighting, and more to come.
    Artist-oriented design While it may not be obvious in this early state, Synfig (and its proprietary predecessors) has ben designed from the ground up with animation workflow in mind.
    Path-based Gradients Unlike purely SVG-based vector software, and most consumer-level animation programs, Synfig has full support for gradiente paths - gradients that follow along a drawn shape. This allows artists to easily add software shading to animation without the trouble of painting it onto every frame. Layers Synfig supports a multitude of layers of various types; geometric, gradients, filters, distorsións, transformations, fractal and a few others.
    Link: http://www.synfig.org/cms/.
    Última edición por Neo_one; 26-05-2014 a las 22:26
    Thumbs up Synfig Studio en la actualidad
    La aplicación de uso libre mantiene su relevancia como una herramienta de animación 2D de código abierto que continúa evolucionando activamente. La comunidad de desarrolladores y usuarios sigue aportando mejoras regulares, corrigiendo errores y añadiendo funcionalidades que mantienen el software competitivo frente a alternativas comerciales.
    Su capacidad para producir animaciones vectoriales y de mapas de bits sin necesidad de frame by frame manual lo convierte en una opción sólida para proyectos independientes y educativos.
    Estado actual del desarrollo
    El desarrollo de Synfig Studio avanza de manera constante aunque moderada, con nuevas versiones que incorporan mejoras en estabilidad y flujo de trabajo. Recientemente se han implementado mejoras significativas en el rendimiento del motor de renderizado y en la interfaz de usuario, haciendo más eficiente el proceso de animación.
    La plataforma sigue siendo completamente gratuita y de código abierto, manteniendo su filosofía original mientras se adapta a los estándares actuales de producción.
    Características y capacidades actuales
    Entre sus fortalezas actuales destacan el sistema de huesos para animación esquelética, los interpoladores de curvas para movimientos suaves y el soporte para capas avanzadas con efectos. La herramienta maneja eficientemente animaciones con interpolación automática, permitiendo crear movimientos complejos con menos puntos clave.
    Su compatibilidad con formatos modernos y la capacidad de exportar en diferentes resoluciones lo hacen viable para proyectos web, televisión y cine independiente. La integración con otras herramientas del pipeline de producción mediante formatos estándar sigue siendo una prioridad en el desarrollo.
    Aunque a veces parece que los desarrolladores tienen más paciencia que un personaje esperando su keyframe, la verdad es que cada actualización acerca más el software a la perfección que todos esperamos.
    Puedes descargar la aplicación gratuitamente aquí.
  1. Noticias Spring open movie Blender animation studio
    : 26-10-2017, 14:01
  2. Synfig software de animación 2d
    : 28-04-2015, 18:41
  3. Noticias Nuevo synfig studio
    Por batou en el foro Noticias 3D
    : 09-06-2011, 17:03
  4. Videojuegos Software de código cerrado vs open source
    Por Metalyang en el foro Videojuegos
    : 05-06-2011, 19:26
  5. Noticias Blender nominado al pack open source graphics software award
    Por ajedros en el foro Noticias 3D
    : 16-10-2010, 10:18
