Cómo hacer para que los bones sean flexibles
    Mar 2009
    Como hacer para que los bones sean flexibles?
    Hola compañeros, estoy haciendo un rigg facial, y la verdad no sé cómo colocar los Bones, para que sean flexibles (estirar y contraer). Hasta ahora el rigg lo tengo hecho, pero con Splines que hacen las veces de Bones, pero no sé si esto sea correcto.
    Por favor si alguien sabe, se lo agradecería. Saludos.
    Puse este código que hice en otro foro. A ver si te sirve.
    Código:
    -Select two points or more points and run the code below for creating a stretchy bone or a stretchy chain.
    Fn makenubbone lastbone =
    Local pues = lastbone, transform[4] - Get the position of the last bone.
    Local xdir = lastbone, transform[1] - Get the Vector of the x point.
    Local startpoint = pues + xdir * lastbone, length.
    Local endpoint = startpoint + xdir * lastbone.width.
    Local nubbone = bonesys, createbone startpoint endpoint lastbone, transform[3] - Create the bone.
    Nubbone.width = lastbone.width.
    Nubbone, height = lastbone, height.
    Nubbone.wirecolor = lastbone.wirecolor.
    Nubbone, parent = lastbone.
    Nubbone, name = lastbone, name + _nub.
    Return nubbone).
    Fn pointfilt o = (classof o == point).
    If selection, count == 2 do.
    If classof selection[1] == point and classof selection[2] == point then.
    Thepoints = selection as array.
    Thebone = bonesys, createbone thepoints[1], pues thepoints[2], pues thepoints[1].transform[3].
    Thenub = makenubbone thebone.
    Thebone, position, controller = position_constraint().
    Thebone, position, controller, appendtarget thepoints[1] 100.
    Thenub, position, controller = position_constraint().
    Thenub, position, controller, appendtarget thepoints[2] 100.
    Thebone, rotation, controller = lokat_constraint().
    Thebone, rotation, controller, appendtarget thepoints[2] 100.
    Thebone, rotation, controller, viewline_length_abs = false.
    Thebone, rotation, controller, upnode_world = false.
    Thebone, rotation, controller, pickupnode = thepoints[1].
    Thebone, rotation, controller, upnodeaxis = 2.
    Thebone, rotation, controller, estoupaxis = 2).
    Else messagebox selected objects must be points).
    If selection, count > 2 do.
    Thecnts = #().
    Thebones = #().
    For I = 1 todo (selection, count-1) do.
    Thecnt = point transform:thepoints[i].transform box:on cross:of axistripod:of size:1.
    Thecnt, parent = thepoints[i].
    Thebone = bonesys, createbone thepoints[i], pues thepoints[i+1], pues thepoints[i].transform[3].
    Append thecnts thecnt.
    Append thebones thebone).
    Thenub = makenubbone thebones[thebones, count].
    Thenubcnt = point transform:thenub, transform box:on cross:of axistripod:of size:2.
    Append thebones thenub.
    Append thecnts thenubcnt.
    Thetarget = (pickobject Prompt:enter a point filter:pointfilt).
    Thenub, position, controller, appendtarget thecnts[thecnts, count] 100.
    For I = 1 todo thebones, count-1 do.
    Thebones[i].position, controller = position_constraint().
    Thebones[i].position, controller, appendtarget thecnts[i] 100.
    Thebones[i].rotation, controller = lokat_constraint().
    Thebones[i].rotation, controller, appendtarget thecnts[i+1] 100.
    Thebones[i].rotation, controller, viewline_length_abs = false.
    Thebones[i].rotation, controller, upnode_world = false.
    Thebones[i].rotation, controller, pickupnode = thecnts[i].
    Thebones[i].rotation, controller, upnodeaxis = 2.
    Thebones[i].rotation, controller, estoupaxis = 2).
    For I = 2 todo thebones, count do.
    Thebones[i].parent = thebones[i-1]).
    Else messagebox pléase select two objects.
    Selecciona dos o más puntos y ejecútalo.
    Mar 2009
    Muchas gracias IkerClon, voy aprobarlo a ver.
    Mar 2009
    Iker ya lo probé, men muchsimas gracias, eres un teso, en el tema. Pero tengo una pregunta, el max no tiene esa opción? Yo no sé dónde vi eso, o no sé si lo soñe o que.
  1. Impresoras 3D Sensores 3D flexibles para plantillas inteligentes
    Por 3dpoder en el foro Impresoras 3D
    : 06-10-2025, 06:05
  2. Impresoras 3D Cómo mejorar la resistencia de los materiales con redes flexibles
    : 03-02-2025, 10:44
  3. No logro hacer que las sombras de un interior sean reales
    Por jark en el foro Render, Iluminación y Cámaras
    : 04-04-2023, 13:48
  4. Cómo hacer que max y XSI sean amigos
    Por Sloft en el foro Plugins y Scripts
    Respuestas: 14
    : 14-12-2008, 18:40
  5. 3ds Max Cómo hacer piel a una estructura de bones
    Por leonardoflores1976 en el foro Animación y Rigging
    : 02-06-2006, 19:18
