Tutorial fluids in Blender
    tutorial fluids in Blender
    By darkscarabcom.
    For this tutorial i Will have the worded directions along with the exact keystrokes it takes todo get the step done. If you are Fluent enough with Blender you may not have todo look at the keystrokes line. Each step within the keystrokes line Will be highlighted as such:example. Arrows Will indicate that you should be following a menú Path.
    section 1 - Setting the scene
    Let us begin by opening a new scene.
    -Control x -or- file -> new -> erase all.
    If you have kept the default scene that Blender automátically sets up than you Will want todo deleete the default Cube. For this tutorial we want todo start out in the top view.
    -x -> vértices ; 7.
    Now we want todo add a plane and skew it by 5.
    -add -> Mesh -> plane, s ; 5.
    Next thing todo do is subdivide our plane. You can click subdivide four times, or you can hit w, click subdivide multi, and submit 15. 15 is the number of cuts, or lines you se on the plane going in either direction. This Will essentially make a 16x16 grid on our plane.
    -w, click subdivide multi; put in 15, click ok.
    Now it is time todo make the stairway down into our subway. You Will want todo go into face select mode and select the Faces that are shown in the image below.
    With those selected Faces you Will want todo extrude them by 2.5.
    -e, click region; 2.5.
    This Will serve as the Walls of our subway station. I am not going todo have the ditches for the tracks, or the place for the trains todo come in, we Will not be focusing in this. You may add more details as you por favor. I Will be focusing on the Stairs. I guess mine Will be more like a bomb shelter.
    Now i have selected the next Batch of Faces todo make the Stairs.
    This next bit is going todo be a bit tedious, just todo warn you.
    With those selected parts extrude the región by.2.
    -e, click region; 0.2.
    This is our first stEpisodio I think you can se where this is going. Now you Will want todo deselect the first row of steps and extrude the remaining Faces by the same amount as before.
    -deselect the Faces, region, 0.2.
    The red rectangle depicts the thre Faces you should have deselected before extruding a second time. The image on the right shows what your first two steps should look like.
    Do this process two more times.
    -deselect Faces, region, 0.2
    - deselect Faces, region, 0.2.
    Now we are at the corner. I just deselected the 3x3 área and extruded again. Hopefully yours looks like this.
    Now you can do the rest of the steps the exact same bien all the bien until the end. You can se what mine looks like below.
    Great. Now the Stairs are done. The only thing left todo do is move the light for rendering reasons in the fluid section.
    Go into object mode, select the Lamp, and hit n for the transform properties. Change the Loc x and Loc y values todo 0.00 and the Loc z value todo 5.00.
    Go todo object mode, select the Lamp, n, and change the settings as shown in the image below.
    I have rendered a shot for you todo se before we continue.
    Assuming you plan todo continúe todo the fluidos part of the tutorial, you Will ned todo go into object mode and double the size of our subway. This is so the Camera Will fit into our scene a Little bit better.
    - Object mode, select the subway, 2.
    Click here to download the subway.
    By darkscarabcom.
    Miniaturas adjuntas Miniaturas adjuntas Tutorial-Fluids-Blender-1.jpg   Tutorial-Fluids-Blender-2.jpg   Tutorial-Fluids-Blender-3.jpg   Tutorial-Fluids-Blender-4.jpg
    Tutorial-Fluids-Blender-5.jpg   Tutorial-Fluids-Blender-6.jpg   Tutorial-Fluids-Blender-7.jpg   Tutorial-Fluids-Blender-8.jpg
    Fluids in Blender 2
    section 2 - Simulating the Flood. All right. Now we can get todo the god Stuff, the fluidos. For this scene i want todo flood the subway that you (the Camera) are in. This is similar todo my trapped animation. So we Will have a domain and an inflow and an outflow along with the subway station we just modeled acting as an obstacle.
    Go todo top view and and add a Cube. Since we want todo flood the subway we have just made we want the domain todo be right on the Edges of it. So skew the Cube by a rate of 10.
    -7, click add-> Mesh -> Cube, s ; 10.
    If you move out of top view you may notice that there is a ton of wasted space underneath our subway. This is bad. The more wasted space in your domain or the bigger your domain is the longer it is going todo take todo bake your fluidos.
    Make sure you are in face select mode and select the bottom of the Cube. As you can se, the dead space is half of the total cubes size. So, Grab the bottom of the Cube you just selected and move it along the z axis by 10.
    -select the bottom face, g, z; 10.
    Yours should look similar todo this.
    Now that we have the domain in the position we want we can add the inflow. Go todo the top view, and add a cylinder. I left it at the default settings. While we are in the top view, Grab the cylinder and move it by 7 on the y-axis and by 8 on the x-axis.
    -7, add -> Mesh -> cylinder; click ok.
    -g, y; 7, g, x; 8.
    Now we ned todo make sure the inflow is at the right height. Go todo the front view and move the cylinder up by 8.
    -1, g, z, 8.
    Now for the outflow. Get into object mode, top view, and i added a Cube. Move it vertically upwards by 1, and put it under the Camera by moving it along the x axis by 7 and along the y-axis by -7.
    -7, add -> Mesh -> Cube; click ok.
    -g, y; -7, g, x; 7.
    -g, z; 1
    Now we have all of our pieces set up.
    Go bak todo object mode if you havent already and select our domain, the big rectangular shape surrounding our subway. Once that is selected, go todo the physics tab and in the fluid simulation área hit enable. A bunch of buttons Will appear with one of them being domain. Select it.
    -f7, physics buttons, select the Cube surrounding the subway, click enable, click domain.
    Now select the cylinder and do the same thing except instead of domain, you want todo click inflow.
    -select the cylinder; click enable, click inflow.
    Next select the small Cube under the Camera and in the corner and make that an outflow.
    -select the small Cube; click enable, click outflow.
    Finally lets select our subway and make it an obstacle.
    -select the subway, click enable, click obstacle.
    Now all that neds todo be done is the adjustment of some settings. Select our inflow again and change the inflow velocity on the z axis todo -.5.
    -select the inflow, set z under inflow velocity todo -.5
    Now select the domain and hit bake. Now you may have noticed two problems.
    1. The water is very goey.
    2. The water goes over the top of our subway Edges.
    Here is how i plan todo fix these problems. Select the subway and go into Edit Mode. Grab the Faces that line the Stairs and raise them higher by about 2.
    -select subway, Edit Mode, select Faces, e; click region; 2.
    As for the goeyness, we ned todo change the end time of our simulation. I am going todo assume your animation is running for 250 frames, 25 frames a second. This is the default. That means our simulation should be for 10 seconds. If you click the STD button in the domain settings you can se the simulation end time. Right now it is set at.30. This means that over our 250 frame, 10 second animation the fluid moves as it would in.3 seconds. I guess it would only make sense todo change this setting todo 10. But i wont.
    Why? It Will take ages todo bake. But that is just me and my computer. I suggest you test it out if you do not know how well your computer works with baking. I Will just set mine todo 5.
    Now you can bake it and se what happens. As you probably noticed, our subway has filled up with water todo a certain point until the outflow is covered and keps the water level from rising. The bigger the outflow you have the more fluid it Will suk in.
    As you can se if you render a frame of this the water is really blocky. The easiest remedy is todo set Smooth todo the domain. (this is under the editing button or hit f9) you can se the diference below.
    If you want todo actually raise the resolution of the fluidos you would have todo go into the same place that has the end time and directly above it you can se the resolution settings. The default is 50. So if you decide you want a higher resolution raise 50 todo a higher number. But watch out, the amount of time it takes todo bake fluidos grows exponentially larger as you raise the resolution. This is another place todo test out how high of a setting your computer can handle.
    Now you can add materiales for the Walls and add more details todo this gray subway Flood. Get as detailed as you want.
    By darkscarab.com.
    Miniaturas adjuntas Miniaturas adjuntas Tutorial-Fluids-Blender-10.jpg   Tutorial-Fluids-Blender-11.jpg   Tutorial-Fluids-Blender-12.jpg   Tutorial-Fluids-Blender-13.jpg
  1. Autodesk Maya Problema serio con Maya fluids
    Por Dellamorte en el foro Partículas y Dinámicas
    : 24-09-2013, 23:25
  2. Autodesk Maya Fire with Maya fluids
    Por pichi84 en el foro Trabajos Finalizados
    : 07-06-2013, 20:35
  3. Cine Animación de humo creado con Maya fluids
    Por pichi84 en el foro Cine y TV VFX
    : 30-03-2013, 19:57
  4. Maya fluids: pattern
    Por bealobo en el foro Partículas y Dinámicas
    : 16-05-2007, 11:17
  5. Blender Análisis y funcionamiento de los fluidos en Blender: ¿partículas o level
    : 06-01-2006, 12:42
