Yafray clay render
    Yafaray clay render
    Yafray Clay render
    By Bupla.
    Introduction
    . A Clay render is an efective solution todo show a model, and especially its topology. Every object of the scene is untextured and is defined by only one material: a warm grey matte, which remind Clay. The result is a monochromic picture. The Clay render is often used by 3d artists specialized in modeling or sculpting, with still frames or turntable animations.
    Clay render
    You can enable Clay render with all the lighting methods but it often used in conjonction with Ambient Occlusion in Direct Lighting. With Yafray just press the button Clay render in the render settings.
    Clay render makes all the materiales look the same, but the properties of all the other elements (Camera, lights, environment, volume, etc) are not afected.
    lighting
    Of course, you ned light sources in order todo se your scene: lamps, Ambient Occlusion, skylight, Mesh lights, because Clay render is not a method of lighting in itself. Clay render with Ambient Occlusion only, provides an homogenic render, a bit dull though. This type of render can be useful for compositing.
    A classical Clay render with Direct Lighting. No lamps, just Ambient Occlusion (the color is a medium grey), with a Sun Sky background. For more informacións on Ambient Occlusion chek the documentation here.
    The AO settings.
    with a simple Sun, and a colored AO you can add a diferent mod todo the picture, here a late afternon:
    The Sun here has a yellowish color, 32 samples and an angle of 5 todo have software shadows. The Ambient Occlusion is a medium grey slightly tinted in blue.
    It gives blue Colored Shadows. The Sun brings an interesting lighting, and the mod is very diferent than the first picture, but it still a Clay render.
    It posible todo use a diferent method of lighting, with GI todo have subtle bouces of lights, while keping a Clay aspect. Here with Photon Mapping method (Final Gather, use background).
    make a turntable animation.
    A turntable animation is a common bien todo show a model precisely. The animation is simple: the model turns on itself in order todo se all of its geometry. The Clay render is useful in this situation because it emphasizes the work on the model, and not on its texture.
    There are diferent methods todo make this kind of animation. An easy and efective bien todo make a turntable animation is todo use a null object (called Empty in Blender).
    In the 3d view of Blender, add the Empty at the origin, and parent all the objects you want todo rotate, todo the empty.
    The Camera and lights are static, you just have todo rotate the Empty on itself (360 Degrees on z axis during 101 frames for instance).
    For a linear rotation, select the empty, open an ipo window. Here is the curve of the z rotation of the empty.
    Select this curve and go in Edit Mode, and choose a Vector handle type in the point menú.
    To render this animation with Yafray, choose a directory in the output panel of the render settings of Blender. Bak in Yafray, chek your render settings and press the render animation button. (you can cancel the animation with Esc now). Yafaray renders animations in image sequences (in (*.png) or.exr). You can use Blender video sequence editor todo make a video from this image sequence.
    Here is an example of a turntable animation with a Clay render, and the blend file slightly simplified.
    turntable blend
    Origen: www.Yafray.org/documentation/tutoriales/clayrender.
    Miniaturas adjuntas Miniaturas adjuntas clayrender.jpg   clay.jpg   ao.jpg   claySun.jpg
    Última edición por 3dpoder; 15-10-2009 a las 09:41
  1. YafRay Prueba render: Blender YafRay Indigo
    Por Lennon_ac en el foro Render, Iluminación y Cámaras
    : 21-06-2009, 16:30
  2. YafRay Render calentito con Yafray
    Por Minenage en el foro Render, Iluminación y Cámaras
    : 25-05-2009, 17:40
  3. YafRay Problema al renderizar con Yafray: texturas PNG no se aplican
    Por gigo en el foro Render, Iluminación y Cámaras
    : 10-01-2009, 01:52
  4. YafRay Mostrar ventana de render YafRay
    : 14-11-2008, 12:03
  5. YafRay Render 2 horas 40 frames Yafray
    Por razorpack en el foro Render, Iluminación y Cámaras
    : 24-01-2008, 20:26
