Técnicas de iluminación con Mental Ray Sun en 3ds Max
    Mental ray Sun
    Mental Ray Sun
    By magic wand.
    Hi.
    Recently i browse th rouge the net in search of a tutorial that explains the lighting techniques in 3ds Max very well, y found my tutorial but, there was another shocking Discovery, that is, there are very rare examples in the whole net for Mental Ray Sunlight and Mental Ray skylight in 3ds Max.
    Some people Will be having an idea about what i am talking, but those who are not familiar with this, let me explain. Mental Ray Sun and Mental Ray are introduced in 3ds Max 9, as a powerful utility todo recreate Sunlight in render with the help of Mental Ray and Final Gathering. Actually it can efectively recreate the Sunlight with exact time and location values, more than that its running on Mental Ray and when we are using Final Gather, the light is distributed correctly todo give a great rendering. Following are the steps todo do it easily, everything is available on max, we have todo find it and use it. Lets go th rouge the procedures.
    * open your scene and set your rendering for Mental Ray.
    * now from the create menú(not the create panel) go todo systems > Daylight system.
    * just create the system and max Will ask you for an exposure control change, just press ok.
    * when you are creating a Sunlight system you Will be creating a compass first and then the light, for that drag the compass in top view port and then create the light.
    * change the Sunlight todo Mental Ray Sun and the skylight todo Mental Ray Sky then max Will again ask you for creating an Mental Ray Physical Sky as the environment map, just press ok.
    * you are almost done now from the date, time and location button below the Daylight parameters you Will get a window like this, from there you can change the location, time and date of the scene, just like the real world max Will change the Sun position and a los the Sky color automátically.
    * now render your scene with Final Gather enabled, isnt it nice?
    * i got a result like this.
    Gracias you.
    Miniaturas adjuntas Miniaturas adjuntas post%2Bpic_001.jpg   post%2Bpic_002.jpg   post%2Bpic_003.jpg   post%2Bpic_004.jpg
  1. Mental Ray ¿Buscas tutoriales de iluminación con Mental Ray para interiores y
    Por jucc en el foro Render, Iluminación y Cámaras
    : 29-12-2007, 18:44
  2. Respuestas: 3
    : 10-06-2007, 17:08
  3. Mental Ray Gi con Mental Ray
    Por marpesia en el foro Render, Iluminación y Cámaras
    : 11-05-2007, 11:00
  4. Mi primer trabajo con Mental Ray: ¿cómo mejorar el efecto neón?
    Por CHA-B-TIN en el foro Trabajos Finalizados
    : 04-05-2005, 04:12
  5. Error al inicializar Mental Ray en 3ds Max y alternativas de render con
    Por molko en el foro Programas de Diseño 3D y CAD
    : 27-03-2004, 05:46
