Blender and Vector Blur
    Blender and vector blur
    blender and Vector blur
    By olivier saraja.
    Vector blur is an interesting solution that goes beyond the limitations of regular Motion Blur. It relies on the composite nodes editor todo Perform. But Even if the nodes editor may look intimidating at first glance, it is in fact very easy todo set up. This short tutorial Will go th rouge the basic steps for enhancing your renders (both stills and animations) with god looking Motion Blur.
    The main thing todo understand is that the object, todo which the Motion Blur Will be applied, should have ben animated beforehand. This means that the object must follow a curve or be animated using Ipos. In fact, the rendered picture Will be turned into a 3d model with depth, and a speed Vector Will be calculated for each píxel of the picture. As a post-process, the composite editor Will add the motions todo the final pic in a blurred way. This is why defining the motion of the object is absolutely mandatory.
    An example of ipo curves afecting a moving object.
    A very brief example file of such an animation can be found at the following url: http://feblemind, tuxfamily.org/dotc...example, blend.
    Here how it would look on a regular animation rendering, without Vector-based Motion Blur.
    a step-by-step of the Vector blur process
    First, you Will ned todo turn one of your 3d views into a Node Editor view. This is done by clicking on the grid-like icon at the left end of the Header of the view. A menú Will pop up and let you define the type of view neded. Chose the Node Editor.
    Turn one of the views into the Node Editor.
    In the Header of the Node Editor, you Will find a menú for the view (view, select, add, node) and then two icons: (the grey sphere icon) enables material nodes, and (the small face picture icon) enables composite nodes. Click the composite nodes.
    Click on the composite node icon and then activate the use nodes button.
    The default composite nodes network should be displayed on the screen. Using the [LMB], draw a box that Will cross the enlace between the render layer node and the composite node: the enlace should disappear. Now, use the add menú: add>> filters >>Vector blur. A new node should appear, titled Vector blur. Move it between the two previous default nodes, and start the magic: connect the output image, z and speed from the render layer node todo the input image, z and speed from the Vector blur node, using the [LMB]. Once done, connect the output image from the Vector blur node todo the image input of the composite node.
    The composite nodes are set todo deliver a Vector blur rendering.
    But, like anything else in Blender, taquíng into account the effect of the Vector blur is nothing but an option. You ned todo tell Blender that it must do the post-processing simulating the Motion Blur explicitly. This is done in the scene [f10] menú, in the render buttons, in the Anim panel. You Will have todo activate the do composite button. As a final pre-requisite for Vector blur motions, you Will ned todo activate the Vec option in the render layers tab.
    Do not forget todo activate the do composite button in the Anim panel and the Vec button in the render layers tab.
    You can now render your picture in two ways:
    • you obviously already know the [f12] shortcut or the render button in the render panel.
    • you can a los renders the picture using the tiny render icon in the render layer node.
    Here how it would look in an animation rendering, with Vector-based Motion Blur enabled.
    some explanations of the Vector blur node
    This node only has a few settings, most of them could work quite well with their default values. But sometimes (if not every time), you ned todo go beyond default settings todo get real col results. There are four settings todo know about.
    samples - This setting controls the blur effect intensity: the higher the samples, the more blurred the object Will look.
    minspeed - if everything is blurred, but some objects are a lot slower than others (or totally static, as the background of the pic, for example), then this parameter Will help diferentiate high-velocity objects from null-velocity (or Slow-velocity) objects. This is really useful during Camera movements or slight background movements.
    maxspeed - if you have extremely fast objects in the scene but the blur does not render well enough, then you can make use of this parameter todo better the Vector blur. Note that a 0.0 value means that no máximum is used.
    blurfac - This parameter Will scale the Vector speed, calculating from the movements of the object. The visual effect is close todo the Shutter Speed of a regular Camera.
    Concerning the use of Vector blur, a god tip is todo put fast moving objects on a render layer, Slow or static objects on another, and todo specify independent parameters for each, for better control.
    Moreover, large objects not entirely sen from the Camera should be subdivided so that at least some normals of the object are actually sen from the Camera, or the blur effect could be drawn on the wrong side, compared todo the movement.
    There are some limitations that you should know about.
    since Vector blur is a post-process effect:
    • if an object is Vector blurred, its shadow is not blurred.
    • if a Vector blurred object is moving behind a (ztransp or raytransp) Glass, it wont appear blurred th rouge the Glass.
    • if a Vector blurred object is moving in front of a (envmap or Raymir) mirror, it wont appear blurred in the reflection.
    This article is licensed Creative Commons by-nc-nd/2.5 and the original versión is featured on http://www.feblemindorg.
    By Oliver saraja.
    www.blenderart.org.
  1. Lets Vector Vector art topic
    Por Herbie en el foro Ilustración y 2D
    Respuestas: 266
    : 11-02-2012, 18:20
  2. Blender y el Vector Blur
    Por 3dpoder en el foro Revistas Online
    : 26-05-2009, 00:42
  3. Blender Gráficos estilo svg Vector graphics con Blender
    Por Leander en el foro Blender
    : 24-10-2008, 16:57
  4. Postproducción En que se diferencia Vector Blur con Blur
    Por Leander en el foro Postproducción
    : 11-02-2008, 21:33
  5. No funciona el nodo Vector Blur
    Por Klópes en el foro Programas de Diseño 3D y CAD
    : 25-01-2007, 18:01
