Hola soy nueva en el foro. Quiero empezar a trabajar con el motor Ogre 3d y tengo varios problemas. Ya instale todo como dice la guía de instalación y al intentar ejecutar la aplicación me salen errores:
- Build: debug in prueba -.
Cl : command line warning d9002 : ignoring unknown option -mthreads.
Main, cpp.
Cl : command line warning d9002 : ignoring unknown option -fmessage-length=0.
Cl : command line warning d9002 : ignoring unknown option -fexceptions.
Cl : command line warning d9002 : ignoring unknown option -fident.
Linking console executable: c:\ogresdk\bin\debug\prueba, exe.
Link : warning lnk4044: unrecognized option /wl,-enable-runtime-pseudo-reloc, ignored.
Link : warning lnk4044: unrecognized option /wl,-enable-auto-image-base, ignored.
Link : warning lnk4044: unrecognized option /wl,-add-stdcall-alias, ignored.
Link : warning lnk4098: defaultlib libcmt conflicts with use of other libs, use /nodefaultlib:library.
Main, obj : error lnk2019: unresolved external symbol __imp__messageboxa@16 referenced in function __catch$_winmain@16$0.
Main, obj : error lnk2019: unresolved external symbol __crtdbgreportw referenced in function public: char const & __thiscall STD:_string_const_iterator<char, structure STD:char_traits<char>, class STD:allocator<char> >:operator*(Void)const (¿d? $_string_const_iterator@du? $char_traits@d@STD@@v? $allocator@d@2@@STD@@qbeabdxz).
Libcpmtd, lib(stdthrow.obj) : error lnk2001: unresolved external symbol __crtdbgreportw.
Libcpmtd, lib(xmbtowc, obj) : error lnk2001: unresolved external symbol __crtdbgreportw.
Libcpmtd, lib(xdebug, obj) : error lnk2019: unresolved external symbol __malloc_dbg referenced in function Void * __cdecl operator new(unsigned int, structure STD:_debugheaptag_t const &, char *, int) (¿2@yapaxiabu_debugheaptag_t@STD@@padh@z).
Libcpmtd, lib(xmbtowc, obj) : error lnk2001: unresolved external symbol __malloc_dbg.
Libcpmtd, lib(xdebug, obj) : error lnk2019: unresolved external symbol __fre_dbg referenced in function Void __cdecl operator delete (Void *, structure STD:_debugheaptag_t const &, char *, int) (¿3@yaxpaxabu_debugheaptag_t@STD@@padh@z).
Libcpmtd, lib(xmbtowc, obj) : error lnk2001: unresolved external symbol __fre_dbg.
Libcpmtd, lib(_tolower, obj) : error lnk2019: unresolved external symbol __calloc_dbg referenced in function __getctype.
C:\ogresdk\bin\debug\prueba, exe : fatal error lnk1120: 5 unresolved externals.
Process terminated with status 1120 (0 minutes, 33 seconds).
10 errors, 4 warnings.
Que debo hacer?
Estoy usando visual C++ 2005.
  Citar
