Resultados 1 al 10 de 10
Vray Fur carpet
    Sep 2008
    3dsmax Vrayfur carpet
    Im an Italian freelance, ive a problem with a carpet (alfombra)
    I wanted to know like making a carpet with like that one in figure.
Nombre: carpet2ey8.jpg
Visitas: 7609
Tamaño: 99.2 KB
    lo siento for my english.
    Compliments for the forum.
    Última edición por 3dpoder; 09-10-2008 a las 17:33
    Oct 2005
    Vrayfur carpet
    Well, here you have a god tutorial by pusa. http://www.foro3d.com/f112/VrayFur-alfombras-43050.html.
    Welcome an enjoy it.
    suBresiduo.
    móviles
    renders
    dibus
    Sep 2008
    Vrayfur carpet
    I have watched the tutorial (very god) but i do not understand like making that effect, lo siento.
    Oct 2005
    Vrayfur carpet
    I ve supposed that you are using 3dsmax with Vray. If you don te know Vray you can te use this command. Called VrayFur.
    You must say us what software are you using.
    Edito: lo siento i did remembered that you ve wrote: VrayFur carpet.
    The same tutorial more explicit, in español.
    Look here.
    Última edición por Miguelit0; 03-09-2008 a las 14:35
    suBresiduo.
    móviles
    renders
    dibus
    Sep 2008
    Vrayfur carpet
    I using 3dsmax 2009 + Vray 1.5 service pack 2, the tutorial have a various effect from the photo that i have mailed.
    Última edición por tacos; 03-09-2008 a las 15:00
    Sep 2007
    Vrayfur carpet
    Hello tacos, you ned to try with bend direction map (RGB) in maps of VrayFur, put in there a map whit the bien you want, and experiment, its the best bien to learn, IM not so sure but this is the right bien to do it, but you told me ok.
    www.boanner.deviantart.com
    www.blarqestudio.es.tl
    www.facebook.com/boanner
    La primera forma de utilizar nuestra libertad individual es la de abrir nuestras mentes a la buena y veraz información que ya está disponible. Héctor Amézquita
    Sep 2008
    Vrayfur carpet
    Ok i try.
    Sep 2008
    Vrayfur carpet
    Nada de nada.
    Sep 2007
    Vrayfur carpet
    I hope this scene can help you, y just put a bitmap in place that i mention before, after placing move the parameters of height and Gravity of Fur.
    I think you ned the bitmap in black and white, that work better.
    Ok made your tests and let me know.
Nombre: fur.jpg
Visitas: 463
Tamaño: 193.5 KB
    Sep 2008
    Vrayfur carpet
    Gracias.
  1. Respuestas: 0
    : 10-10-2017, 14:23
  2. 3dsMax Ventana del Vray frame buffer es lenta 3ds Max 2012 Vray 2 10 01
    Por estebang en el foro Programas de Diseño 3D y CAD
    : 13-07-2012, 12:30
  3. V-Ray Vray Rhino-Vray Sketchup-Vray max
    Por juanmamondejar en el foro Render, Iluminación y Cámaras
    : 22-11-2010, 11:51
  4. V-Ray Vray fur en pelota de tenis la rompo y el Vray no sigue a las piezas rotas
    Por perineo en el foro Materiales y Texturizado
    : 26-06-2010, 14:10
  5. V-Ray Parámetros Vray Sun Vray Sky y Vray physical Camera
    Por ancemo5 en el foro Render, Iluminación y Cámaras
    Respuestas: 19
    : 30-04-2009, 21:46
