Resultados 1 al 28 de 28
Wings3d 0 99 xx release y avances
    Wings3d Wings3d 0-99-xx release y avances
    Wings3d 0.99.00a. Después de poco más de un año sale una nueva versión de este potente, versátil y ligero programa de modelado open source.
    Ya sabéis, descarga gratuita en Wings 3d.
    Development reel: 0.99.00a.
    Mac | win | Linux | source | notes.
    Tutoriales: videotutoriales en castellano
    videotutoriales recopilados en 3dpoder
    Wings 3d - Foros 3dpoder..
    Notas:
    Cita Iniciado por örn
    here is the new release. It is based on erlang/otp r12b.
    I have tested the Mac versión on both Mac os 10.4 (pc) and Mac os 10.5 (Intel).
    I have tested the Windows versión on Windows XP (sp2), running in Parallels.
    (a virtual computer) on my Imac.
    I have tested the Linux versión on openSUSE 10.3, running in Parallels on my.
    Imac. I hope that it should work on all modern Linux systems.
    If there are any obvious problems in this reléase that are easy todo fix, there might be another reléase before Christmas.
    Enjoy.
    /björn.
    Cosmetic improvements: the menú selector has a subtle gradient, and the title.
    Bars have the common aqua/vista effect. Alos added optional history buttons.
    (aka undo/redo) and open/save icons on menubar. [scorpius].
    Added more Shaders (brick, ton, environment-mapping, goch-tone), which can.
    Now be toggled (or cycled) th rouge a choice in the view menú. Requires an.
    OpenGl 2.0 video card. [scorpius].
    Revised most primitives, they are now more accurate and have more options.
    [contributed by Richard Jones (optigon)].
    Ability todo set drag constraints for the currently pressed modifier key(s), when one Edge is selected the distance constraint is set, when two are.
    Selected the rotation constraint is set. [scorpius & optigon].
    Added ISO-8859-9 font support. [contributed by ismail keskin (devilgren)].
    Added search in relative paths when loading textured models. [dgud].
    Ability todo set drag constraints. [contributed by Richard Jones (optigon)].
    Small add todo right mouse button absolutesnap, now you can look movement.
    In x, y or z. [giniu].
    Changes todo absolute scale, ability todo enlace sizes (uniform scale), ability todo.
    Pik scale centre from scene using RMB absolute scale, ability todo pik target.
    Size from scene using Mb absolute scale and option todo fit selection into.
    Picked target by automátically adjusting scale centre. [giniu].
    Pov-Ray exporter and renderer added.
    [contributed by Chris hegarty (avariant)].
    Added a live miniature-axis icon todo the lower-left corner of the screen.
    [scorpius].
    Added a user defined clipping-plane. Use set default axis todo interactively.
    Change the orientation of the plane.
    Edges can now be displayed with antialiasing, se preferencias. [scorpius].
    Added russian translation by Paul geraskin. [Bjorng].
    Major update todo portuguese translation [contributed by: luiz fonte boa]. Wings 3d.
    Última edición por SHAZAM; 19-12-2007 a las 00:58
    Victor Navone
    Chuck Jones
    John Lasseter
    Wings3d 0-99-00a release
    Descargando. Leyendo. Eh? Cómo? Un año, y solo media página de cambios. (Es broma.
    En slackware 12.0 en principio funciona.
    Posiblemente haya otra actualización esta semana. Esperemos que no sea de media página.
    Victor Navone
    Chuck Jones
    John Lasseter
    Feb 2005
    Tiene pinta de ser sencillo de utilizar, ¿sabéis donde encontrar tutoriales de calidad para utilizar este programa? Un saludo.
    Esperando noticias de Autodesk.
    Feb 2005
    Vaya, me parece que le he pillado ya el truco. Este programa se puede utilizar de forma comercial gratuitamente o hay que pagar?
    Es opensource, puedes hacer lo que te plazca con él.
    Sencillo, potente y más utilizado de lo que se piensa y dice.
    Victor Navone
    Chuck Jones
    John Lasseter
    Feb 2005
    Thumbs up Wings3d 0-99-00a release
    Gracias Shazam, eres grande.
    Es opensource, puedes hacer lo que te plazca con él. Sencillo, potente y más utilizado de lo que se piensa y dice.
    Tutoriales: videotutoriales en castellano. videotutoriales recopilados en 3dpoder. Wings 3d - Foros 3dpoder..
    Wings3d 0-99-00a release y avances
    Wings-0.99.00b.
    notes:
    - Creating a Normal Map for a material was so Slow so that it semed.
    That Wings was Frozen. Now bak todo normal speed. [Bjorng].
    Attempting todo create or edit a material when the Yafray plug-in was active.
    Would cause a crash. Corrected. [Bjorng].
    Eliminated the problem that caused some lenguaje files todo be corrupted.
    On Windows. Alos added verification todo the the build process so that.
    This problem Will be detected if it should occur again. [Bjorng].
    In the Misc tab in edit | preferencias, Camera moves and interactive commands.
    Are Jumpy is now default on all versións of Mac OSX. A buggy versión number.
    Chek turned it of on Leopard. (gracias todo jtico.) [Bjorng]</pre>.
    http://switch, dl.sourceforge.net/so...s-0.99.00b.exe. Saludos, ala2.
    Victor Navone
    Chuck Jones
    John Lasseter
    ¿Solo tiene 1 nivel de Subsurf con shift-tab?
    Buena pregunta.
    Victor Navone
    Chuck Jones
    John Lasseter
    A mí me gusta Wings porque en Blender cuando tengo un modificador Subsurf configurado para que no se aplique en Edit Mode y con set smooth, no me deja las caras lisas en modo shaded en Edit Mode, están difuminadas y no me parece cómodo.
    Cuando se modela orgánicamente normalmente se hace sin Subsurf, esto está ahí para ir activando/desactivando a placer para comprobar la fisionomía, pero si en Wings no me da una aproximación adecuada (con solo 1 nivel) no me parece indicado para dedicarme exclusivamente a este.
    Había un plugin que permitía hasta cuatro niveles de subdivisión, pero daba algunos problemas en algunas tarjetas. Si me entero de algo te aviso, la verdad es que un programa como Wings debería tener ese tema más que solucionado.
    El truco es aplicar la, shift + tab y luego el undo (Control + Alt+z) pero obviamente es muy molesto y arriesgado si uno se despista.
    Victor Navone
    Chuck Jones
    John Lasseter
    Menos mal que se puede retroceder un pasito (y no se nota).
    Necesitas: Wings3d 0.98.36 (versión inmediata anterior)
    parche.
    Descargar e instalar Wings3d 0.98.36 y descomprimir el parche.zip dentro de la carpeta que se indica en el gráfico-minitutorial y configurar preferencias según el mismo.
    Tienes hasta cuatro niveles de subdivisión (se recomienda no utilizar más de dos).
    That all folks.
Nombre: wings_subdiv_shaz.png
Visitas: 178
Tamaño: 95.0 KB
    Victor Navone
    Chuck Jones
    John Lasseter
    Okay. Gracias. ¿Y porqué no lo han implementado en la 0.99?
    Eso se preguntan muchos usuarios, es algo demasiado básico.
    Hay un parche para la extra oficial 0.98.37se, pero no le funciona a todo el mundo igual, a mí me cuelga el programa y tampoco sirve para la 0.99.
    Esperemos que lo implementen pronto.
    Victor Navone
    Chuck Jones
    John Lasseter
  16. #16
    Ya ha salido Wings3d 0.99.01. Descargas: Wings 3d.
    Reléase name: 0.99.01.
    Notes:
    - New feature: edit|plug-in manager. It allows you todo selectively.
    Enable and disable plugins, for instance, you can turn of all.
    Export and import plugins for formats that you never use. (note todo.
    Translators: since there may be changes todo this característica, depending.
    On the feedback, y have deliberately not made the string.
    Translatable yet.) [Bjorng].
    Hotkeys can now a los be assigned todo commands that are invoked using.
    Mb or RMB. [Bjorng].
    On Windows, Wings Will now remember if it was maximized when it was.
    Quitted, and automátically start maximized next time. [Bjorng].
    View|saved views|save Will now count as change, so that the file can be.
    Saved immediately without workarounds such as selecting something first.
    (gracias todo ort.) [Bjorng].
    Tweak mode: there would be a crash if you attempted todo relax a face.
    Next todo a hidden face. Alos updated the look of the información in.
    Line todo look more as the rest of Wings. Alos made sure that.
    Modifiers that Will not work in the motionbuilder Camera mode are.
    Not shown on the información line. [Bjorng].
    Turn command: in the basic menús, there are now thre turn commands:
    Turn clockwise, turn counter-clockwise, and turn optimized.
    In advanced menús, those thre commands can be chosen using LMB, Mb, and RMB. The preference dialog in edit|plug-in preferencias has.
    Ben eliminated. There is no longer any automatic hotkeys assigned.
    There Will now be an error dialog if you have selected more than one.
    Edge in the same face (instead of a mess). [Bjorng].
    Ayuda|OpenGl info now a los reports the SDL versión. [Bjorng].
    The experimental support for cycling Shaders have ben turned of.
    Until it can be done properly. [Bjorng].
    The portuguese and french translations have ben updated.
    Victor Navone
    Chuck Jones
    John Lasseter
  17. #17
    Sep 2004
    Aún sigue sin poder ponerse imágenes de fondo?
  18. #18
    ¿Para utilizar imágenes como blueprints? No creo, pero mejor que lo investigues tú mismo, suelo colocar images planes, como es tradicional en este programa.
    Victor Navone
    Chuck Jones
    John Lasseter
  19. #19
    Apr 2006
    Hey no había visto esto. Bajando.
  20. #20
    Wings3d v0.99.02. descargas e información.
    reléase name: 0.99.02.
    notes:
    - Now using erlang/otp r12b-1. The build instructions have ben updated with.
    More details. The SDL library in the Linux distribution no longer referencias.
    Liba (gracias todo vtechk). [Bjorng].
    Verbose and mouseover información text options added todo edit|preferencias|general.
    [optigon].
    Added interfaz options todo edit|preferencias|general. Options todo.
    Edit the width of hard Edges and normals, and set the default colour.
    Of the default and hole material. Also, the mini axis can now be.
    Switched on or of and the colour of its axes are now linked todo the.
    Main axes. [optigon].
    -Wings could crash when triangulating (for display purposes)
    Extremely degenerated Polygons. For instance, cilíndrica shift.
    On a cylinder could cause the problem. (gracias todo pauljs75.)
    [Bjorng].
    In secondary selection mode, invoking some selection commands (such.
    As select|similar normals) would cause a crash. Also, invoking.
    Select|similar normals th rouge a hotkey in the wrong selection mode.
    (i, not Face Mode) would cause a crash. (gracias todo optigon.)
    [Bjorng].
    Optional feature: changing modes while dragging would make the model.
    Jump. Mode changes can now be set todo reset the model bak todo its initial.
    Position. [optigon].
    Fixed the repeat drag arguments (shift d and d) for vertex intersect, bend, and shift. [optigon].
    Basic mode turn menú now cascades. [optigon].
    Extended Vector ops todo accept vectors defined across múltiple objects.
    Alos added cross product as a bien todo define a Vector using two Edges.
    [optigon].
    New feature: vertex|deform|inflate cilíndrica. Works in both basic.
    And advanced menús. In basis menús, select a central axis (XYZ) and.
    Inflate. In advanced menús, pik a central axis and optionally, pick.
    A center point and Radius. Vértices Will move towards the Radius along.
    A Vector extending from the center point. All vértices are aligned with.
    The Radius when the distance reads 100%. [optigon].
    New feature: vertex|connect(RMB)|connecting Edge (advanced menús only).
    Creates a new Edge by connecting the selected vértices and returns the.
    New Edge already selected. [optigon].
    New feature: edit|preferencias|constraints > drag preferencias.
    Allows you todo customize dragging speed for rotational, absolute, and relative drags. [optigon].
    New feature: this preliminary reléase of the new set constraints plugin.
    Gives you the ability todo take measurement directly from your model and.
    Save them as default constraints which can be used while dragging. You.
    Can take measurements in various ways including the use of secondary.
    Selections and Vector. Bind the constraint todo the modifier key(s)
    Of your choice (alt,shift,Control) by holding them down while accepting a.
    Method of measurement or set a default key combo in the prefs. If the.
    Measurement includes a secondary selection, you may hold down the modifier.
    Keys when finalizing your selection. [optigon].
    Edge mode:
    Total length - Total length of the selected Edges.
    Average length - Average length of the selected Edges.
    Angle - Angle between two Edges.
    Subtract angle - Diference of two angles.
    Edge todo axis - Angle between a single Edge and a chosen axis.
    Percentage - Diference two selections as a percentage.
    Diference - Diference in length of two selections, centers - Distance between the centers of two selections.
    Face mode:
    Percentage - Diference in área between two face selections as a percentage.
    Centers, angle, subtract angle, face todo axis.
    Vertex mode:
    Centers.
    New feature: switch constraint sets on the fly while dragging. Every drag.
    Mode now has two related sets of constraints. You can switch todo the related.
    Constraint set by press shift+tab while dragging in any tool. The related.
    Sets are as follows.
    Scale factor/reciprocal: reciprocal is equal todo 1/scale factor.
    Angle/supplementary: supplementary is equal todo 180 - Angle.
    Distance/alternate distance: two sets for distance constraints.
    [optigon].
    New feature: vertex|deform|shear. This plugin lets you shear vertex selections.
    And more. Drag in all thre modes (absolute, angle, relative). Add curve todo.
    The shear. Use Vector ops or standard axes(XYZ). Many gracias todo puzzledpaul.
    For testing and ofering useful suggestions. [optigon].
    Increased límites of the main Wings primitives todo infinity. [optigon].
    The hotkeys for toggle proxy mode and quick smoothed preview (shift+tab)
    Are now properly ignored in interactive commands and when the Camera is active.
    (gracias todo optigon.) [Bjorng].
    -When defining hotkeys for menús such as edit|preferencias or pop-up menús.
    When advanced menús were not turned on, there could be a useless question.
    About mouse buttons. This cuestión has ben eliminated. [Bjorng].
    The Wavefront importer Will now import objects that have deffects such.
    As invalid texture coordinate referencias. Instead of crashing, texture.
    Coordinates Will be removed from the face in question. Also, import of.
    Wavefront files with relative vertex referencias Will be faster (much.
    Faster for big files). (gracias todo terje7601.) [Bjorng].
    Added new Camera modes: Google SketchUp and Wings 3d suggested by ort.
    Wings 3d mode is the same as Mirai mode, except that the mmb Pans instead.
    Of dollying. Added optional scroll whel activated pan and rotate (available.
    In all Camera modes). Alos extended arrow key panning todo work in all modes.
    And improved its useability. [optigon]</pre>.
    Victor Navone
    Chuck Jones
    John Lasseter
  21. #21
    No me acordaba del Wings3d, con esto si que puedo hacer box modeling. ¿Permite ahora Subsurf sin plugins de manera directa y cómoda?
  22. #22
    Te refieres a subdivisiones? Porque yo también me lo preguntaba.
  23. #23
    Eso mismo, no subdividir la malla sino visualizar con subdivisiones.
  24. #24
    Pues yo llevo un rato trasteando y no lo he encontrado todavía (lo cual no quiere decir que no lo tenga, porque es la primera vez que lo uso).
  25. #25
    Y yo, algo dijo Shazam sobre un plugin, pero quizás sea para versiones anteriores, porque Subsurf se puede, que lo he visto.
  26. #26
    Sí, yo también recuerdo haberlo visto en un videotutorial, en concreto creo que en ese del busto de un romano, pero la verdad es que no acabo de dar con ello.
  27. #27
    Para subdividir el atajo de teclado es la tecla s, si lo que quieres es un previo pulsas shift + tab. Cuando se pulsa la s la subdivisión no es temporal sino es como cuando pulsas el botón apply en el modificador Subsurf en Blender.
    Victor Navone
    Chuck Jones
    John Lasseter
  28. #28
    Eso, el previo, okidokis.
  1. Blender 2.57 release y avances
    Por SHAZAM en el foro Noticias 3D
    Respuestas: 224
    : 22-06-2011, 21:31
  2. Blender 2.49 release y avances
    Respuestas: 1290
    : 23-11-2009, 22:41
  3. Blender 2.48 release y avances
    Respuestas: 558
    : 30-05-2009, 18:38
  4. Wings3d 0 99 04 release
    : 11-10-2008, 03:33
  5. Wings3d 0 99 03 release y avances
    : 21-07-2008, 12:07
