Resultados 1 al 26 de 26
Tormenta de ideas para la Gui de Gimp
    Jun 2003
    Tormenta de ideas para la gui de gimp
    Gimp UI brainestorm: fullscreen + transparency….
    got ideasí.
    This is a visual brainestorm, the channel for a todo el mundo todo contribute todo the Gimp UI redesign process. It is moderated by the Gimp UI redesign team we do not mensaje mock-ups here ourselves, we listen todo what you show us and broaden our horizons.
    To kep things easygoing + fun around here, there are some rules:
    Explain your idea in an image or two. Only these images Will be published, so make sure any neded explanation is inside them. Images must be in (*.jpg), gif, bmp or (*.png) format, máximum 8 Mb each.
    Your images should show your idea in a clear way, but they dont have todo be Glossy and polished. Plain Vector drawings or Even scanned Pencil sketches should a los work.
    Send your image to us, put the Word Gimp in the title of your email (to avoid spam, emails without Gimp in the title or without an image attachment Will not be opened).
    We Will not publish your name or email address, if you want todo be identified with--or Even contacted about--your contribution, place your name or email address discreetely in your image.
    All further text you place in your image can only be used todo explain your own idea. Kep it short, point out what is innovative. If you fel you ned a lot of text todo explain, then maybe your idea is not working on an user interaction level.
    Do not write in your image about other people, other peoples ideas or why Gimp sucks, because.
    Polemic kills brainestorming, hence there are not going todo be discussions or comentarios in this blog. If you want todo vent, use the usual channels. If you have got a better idea, Simply show it todo us.
    If you want todo respond todo a contribution, by all means take the image, modify it with your own ideas for improvement and send it bak todo the brainestorm. Visual dialogue: it is allowed and encouraged by the c licence on this blog.
    We are pretty liberal europeans, but anything obnoxious Will ensure that your image does not get published here. We Will not modify your image in any way, so either it is fit todo be blogged or it Will be discarded.
    Our team Will label your contribution and sometimes we Will write a few sentences of Analysis, if we are not todo busy working on Gimp.
    Your contribution has todo be compatible with the license of this blog. Speaquíng of.
    Como tan parado está el Gimp desde hace tiempo, aunque se haya ido desarrollando por detrás, pero nada de compilaciones.
    Me he pasado al Paint, net que es freeware, pero que avanza de verdad.
    Aug 2007
    Madre tiene pinta de ser cómodo trabajar así, uf esos botones de abajo son todo un detalle. Me encantaría pintar ahí.
Nombre: gimp-transparent-fullscreen.png
Visitas: 1234
Tamaño: 868.3 KB
    Última edición por 3dpoder; 12-04-2008 a las 15:32
    Mi idea para Gimp: que se parezca lo máximo posible a Adobe Photoshop.
    Victor Navone
    Chuck Jones
    John Lasseter
    Aug 2007
    Hay algunas que están muy bien. Gimp UI brainestorm: Windows in window.
    Mar 2006
    Vaya pedazo de interfaz, así da gusto la verdad es que estaba deseando. Estoy deseando pillarla. ¿Esta ya disponible?
    Aug 2007
    Supongo que no, son conceptos, eso creo vamos.
    Mi mensaje número 100.
    Mar 2006
    Lo suyo sería que fuese customizable ¿no? Y así cada uno se la hace a su gusto. Con un deslizador para transparencia por supuesto.
    Enhorabuena por tu pst número 100 antes de que te des cuenta levaras un cero más.
    Aug 2007
    Personalmente no me gusta nada el hecho de que las ventanas independientes, cuando trabajo en patanlla completa, que lo hago mucho, tengo que andar alt-tab a ver si atino con la ventana correcta (lo cual no sucede casi nunca) para hacer cambios de tamaño, color, que haces cada 2x3. Y eso que en Linux nos beneficiamos de poder aparcarlo al un 2º escritorio y así poder abrir alguna aplicación más, en Windows no me quiero imaginar como seria. Saludos y ojalá lo metan todo dentro de la misma ventana, no sé qué ventajas tienen las múltiples ventanas, especialmente con monitores no muy grandes.
    Posdata: Gekonidae ya le he pedido otro 0 a los reyes.
    Jan 2004
    Vaya que pedazo de programa si lo ponen así.
    Obsesionado por la calidad
    Nov 2005
    Debo ser el único al que le gusta la interfaz de ahora.
    Aug 2007
    ¿para qué usas el programa? ¿por qué crees que es mejoré pienso que quizá con una pantalla panorámica grande sea cómodo, quizá yo también lo use mal no sé. En mi caso es muy incómodo y tengo que dar demasiados clicks o atajos de teclado para hacer cosas muy usuales. Saludos.
    Yo lo uso a diario en el trabajo, tengo dos monitores uno para la imagen y otro para los menús. Entiendo que a la gente le sea engorroso trabajar con ventanas sueltas trabajando en una sola pantalla. Esperemos que salga adelante alguna de esas ideas, seria un enorme salto para Gimp.
    he logrado cruzar genéticamente ladillas con luciérnagas. No se para que sirve, pero tengo los cojones que parecen las vegas
    Aug 2007
    A eso me refería, con un gran monitor o con más de uno tiene que ser algo genial, pero con un monitor normalin, no se al menos al mío, me dan ganas de seleccionarle las esquinas y estirarlo.
    ¿Sabéis cuándo saldrá la 2.4? Saludos.
    Nov 2005
    Yo no tengo un pantallón, lo utilizo en un 17 panorámico y en un 19 normal. Yo apenas uso los menús, a pantalla grande y sabiéndote los atajos del teclado es super cómodo por lo menos para mí, saco las capas con f7, los colores con f6, herramientas f5, no te quitan espacio para nada. Pero si lo integran todo en una y luego se puede ocultar, pues mucho mejor, así todo el mundo contento.
  16. #16
    A mí me gustó el GIMPshop, al estar ordenado lo más similar posible a Adobe Photoshop no me perdí tanto. Por lo general a mi casi no me gustan los programas o aplicaciones que tienen demasiados adornos en la interfa, z, algo simple, pero funcional es mejor, según mis gustos.
  17. #17
    El gimshop está bastante bien, pero no lo actualizan para Windows desde hace mucho.
    Victor Navone
    Chuck Jones
    John Lasseter
  18. #18
    A mi eso de las ventanas desparramadas por toda la pantalla nunca me gustó mucho, no me gustaba de After Effects, ni de Photoshop ni Illustrator.
    Para mí el mejor invento de Macromedia fue crear esos menús acoplables a los lados.
  19. #19
    Mar 2006
    A mí me gusta ahora sólo me jod* que salga en ventanas diferentes, prefiero tener una ventana con la imagen y las otras flotantes con transparencia, pero que no queden detrás.
    Y la UI de ZBrush está bien también, con paneles a los lados si quieres ponerlos.
  20. #20
    Aug 2007
    Ojalá lo implementen todo en una ventana, con paneles flotantes. Lo que más temo es que, si quieren hacer esto, pase lo mismo que con Blender y tarden muchísimo en sacar una nueva versión.
    ¿Nadie tiene idea de cuando sale la 2.4? Ya hay dos relases, pero encuentro fechas ni nada. Saludos.
  21. #21
    Jun 2003
    Ve usando las rc, ¿Qué más da que aún no sea la buena? Para ir haciendo van bien. A mí la interfaz actual sólo me molesta porque el foco del ratón no me selecciona la ventana correcta, con lo que siempre acabo pulsando los shortcuts sobre la ventana que no toca, y me frustra un poco. Pero no sé si es algo que hay que configurar en el Gimp o en Ubuntu/Windows.
    Me resulta más prioritario que hayan corregido algunos asuntos sobre vistas preliminares y eventos en tiempo real.
  22. #22
    Mar 2008
    3dsmax Tormenta de ideas para la gui de gimp
    El Gimp tiene muchas funciones, pero la interfaz es pésima, pero hace poco vi una de las últimas ideas y me complació mucho espero la miren es genial, y no es una copia del diseño Adobe Photoshop más bien es del Office 2007 pero está muy bonita e intuitiva. Gimp UI brainestorm: intuitive appearance..
  23. #23
    Jun 2006
    Vaya pues yo voy al revés, debe ser que he usado mucho más Gimp que Photoshop, pero a mi este último nunca me gustó y al Gimp estoy bastante acostumbrado y no encuentro la interfaz tan mala como algunos dicen, las ventanas se pueden mantener siempre arriba con una opción en las preferencias, preferencias->window management->window manager hints-> y seleccionar kep above, eso si lo que es una pena es que lleven tanto tiempo para sacar la versión 3, no solo por las mejoras en la UI sino para que soporte CMYK, 16/32 bits, OpenEXR y el uso de nodos, pero bueno a ver si poco a poco, esto pasa algunas veces con algunos proyectos van muy lentos hasta que la gente que los lleva cambia sacana algo chulo y empiezan a acelerar el desarrollo.
    Un saludo
    Houdini Addict
    Powered by UNIX
    If it looks good enough, it's good!
  24. #24
    Jun 2003
    Pues a mí la interfaz Office me parece un desperdicio tremendo de espacio. Tal y como esta ahora, con la posibilidad de maximizar el lienzo e invocar (u ocultar) las otras ventanas flotantes pulsando el tabulador, me parece un sistema fantástico.
    Lo suyo sería que conviertan la GUI en algo lo más configurable y flexible posible, y luego cada cual se adapte a sus gustos.
  25. #25
    Sep 2004
    La interfaz de Gimp me parece buena, solo que los iconos deberían ser más pequeños. La gran ventaja de Photoshop está en el manejo de capas, más precisamente en el blending options, si Gimp puede igualar ese manejo de capas y de paso igualar el free transform de Photoshop pues si que seria un gran dolor de cabeza para los de Adobe.
  26. #26
    Jun 2006
    En las preferencias puedes cambiar el tema que usa Gimp para los iconoc por unos más pequeños.
    Un saludo
    Houdini Addict
    Powered by UNIX
  1. Cine Ideas para una historia
    Por Nacho47 en el foro Cine y TV VFX
    : 20-11-2009, 04:09
  2. Gimp FX Foundry 2 6-1-mas de 100 efectos nuevos para tus fotografías con GIMP
    : 06-03-2009, 20:10
  3. Ideas para mejorar
    Por el_galan_real en el foro Trabajos en Proceso
    : 08-04-2007, 08:59
  4. Ideas para logotipo
    Por Gepetto en el foro Trabajos en Proceso
    Respuestas: 22
    : 09-06-2006, 21:46
  5. Ideas para un corto
    Por TheOutsider en el foro Programas de Diseño 3D y CAD
    : 28-05-2004, 19:10
