Nodejoe editor de materiales esquematico
    Toda la información en su web, yo lo veo bastante útil. nodejoe.
    Nodejoe is a schematic material editor realiced as a plugin for 3ds Max(TM) that allows you a quick, clear and easy bien of working with textures and materiales. It uses the 3ds Max(TM) internal data structures todo provide compatibility with all the materiales and textures that work with 3ds Max(TM).
    The plugin provides an intuitive, clearly arranged graphical user interfaz todo create, analyse and modify materiales and textures within 3ds Max(TM). The working área is zomable and draggable, presenting an interactive preview of materiales, including all submaterials and subtextures, as well as showing their dependencies between each other. You can create connections between diferent materiales by drawing directly on todo the surface. The integrated automatic Layout provides a clearly aligned diagram - At your fingertips. Nodejoe Will give you a clear overview of the relationship between existing materiales within the current scene.
    Nodejoe was developed by designers for designers. It provides the functionality that we have always missed during our daily working with the materiales inside 3ds Max(TM). Nodejoe has grown up - After a long period of development and internal beta-testing - Into a product that Will leave its beta-phase in a few weks.
    Currently nodejoe cannot be purchased.
    But if you want todo get an idea of nodevaya, you can download the current beta-versión (0.85) for free.
    Última edición por P-S; 25-08-2007 a las 21:59
    Parece muy interesante el plugin, gracias p-s.
    Jan 2023
    Re: Nodejoe editor de materiales esquematico
    Hola compañeros!
    Veo que NodeJoe ofrecía la descarga de versiones beta gratuitas en su web...
    https://web.archive.org/web/20071217...om/beta_en.php
    Desde 3ds max 6 a 3ds max 9
    Lamentablemente la WayBack machine no guardó ninguna copia y no veo que se pueda descargar de ninguna otra parte.
    ¿Hay alguien que por casualidad aún conserve por ahí alguna versión?
    Gracias de antemano!
    Thumbs up Re: Nodejoe editor de materiales esquematico
    Aquí tienes varios enlaces que funcionan, pero tienen troyanos, comprobado, así que la descarga queda a tu criterio.
    https://archive.org/details/autodesk-3ds-max-2009
    Verás que en la misma página te ofrecen otras descargas similares.
    Piensa que, aunque lo encuentres por otro sitio y el navegador o software antivirus te diga en principio que no tiene virus ni troyanos, luego a la hora de instalar aparecen porque están escondidos en el propio instalador, no en el programa en sí.
    Un saludo.
    Jan 2023
    ¡Gracias 3dpoder!
    Pero he descargado la ISO del enlace que has indicado y lo único que veo es una instalación de 3ds max 2009...
    No veo que contenga ninguna carpeta con plugins ...
    No sé si el enlace que querías poner era otro.... ¿? O si es que hay que buscarlo de otro modo... ¿?
    Gracias de antemano...
    Un saludo.
    Última edición por 3dbirdy; 10-08-2025 a las 13:00
    Cita Iniciado por 3dbirdy Ver mensaje
    ¡Gracias 3dpoder!
    Perdona, entendí que buscabas el 3ds Max 9, no un plugin...
    Jan 2023
    3dpoder,
    Como decía en mi primer mensaje (y dado que esta entrada del foro trata sobre ese plugin), sólo buscaba el plugin NodeJoe (plugin para el que solo se hicieron versiones beta gratuitas).
    Por si era de ayuda, indiqué el antiguo enlace original de sus desarrolladores (ya fuera de servicio), advirtiendo de que lamentablemente la WayBack Machine no guardó las descargas....
    ¿No habrá alguien que por casualidad tenga por ahí esas descargas de NodeJoe?
    Gracias de nuevo
    Última edición por 3dbirdy; 11-08-2025 a las 01:23
  1. 3ds Max Problemas con la visualización de materiales en el editor de materiales del 3ds Max 6
    Por mad-max en el foro Programas de Diseño 3D y CAD
    : 05-04-2023, 20:15
  2. No veo el editor de materiales
    Por Arya en el foro Materiales y Texturizado
    : 15-11-2008, 22:31
  3. V-Ray V-ray y el editor de materiales
    Por Frodo en el foro Programas de Diseño 3D y CAD
    : 15-09-2008, 18:52
  4. Editor de materiales
    Por polla3d en el foro Materiales y Texturizado
    : 16-02-2005, 21:31
  5. V-Ray Editor de materiales con materiales Vray
    Por Kinematix en el foro Render, Iluminación y Cámaras
    : 25-03-2004, 01:26
