Resultados 1 al 47 de 47
Silo 2 release y avances betas
    Silo Silo 2 public beta 10a y avances
    Gracias a Elgordo por la noticia e idea de abrir un hilo específico. Esta versión es completamente funcional por un buen tiempo, lo que da oportunidad de probar todas las prestaciones de este estupendo programa de modelado. descargar.
    Here a list of some of the updates for this beta:
    -The topology brush close loop and continúe stroke functionality has ben corrected and restored.
    - Double-clicking on Silo-associated files Will open them in Silo.
    - Several obj improvements, including speed increases and the option todo import/export objects as groups is back.
    - Fixed locking issues. (only objects and object groups are available todo be locked.)
    - Fixed a bug with hiding and unhiding Faces.
    - Fixed a crash when using merge across the mirror seam of a mirrored object.
    - Fixed a spin Edge crash.
    - Updated default preferencias, and added presets for mouse settings.
    - Fixed issues with lazo selection and área selection, so they are much more reliable.
    - Fixed issues with toggle current subdivisión.
    - Fixed a Normal Map generation crash.
    - Added status información for file loading and saving.
    - Fixed (*.png) alpha issues for Normal Map export.
    - Fixed an issue with saving a.sib file with UV proxies as a.sia file.
    - Fixed more general crashes.
    - Opening the brush editor (shift + t) Will automátically enter the displacement brush. Use this command if you want both todo open at once.
    - Fixed an issue on Mac where numerical entry didnt work when a window was not docked.
    Pléase let us know if you have any problems with installation, and of course por favor kep posting about bugs and critical issues.
    And once more, just because it fun todo yell sometimes:
    Important: your registration code Will not work for this beta. You must use it as the fully-functional demo versión.
    Victor Navone
    Chuck Jones
    John Lasseter
    Parece que no está llegando esto a la gente. Y eso que ahora lo pueden probar gratis durante un mes. Desde luego yo recomiendo probarlo al menos.
    ¿A vosotros no os pasa que el mirror geometry os hace cosas raras?
    ¿Qué se supone que te pasa? Si te come trozos o así es porque el modelo no está bien centrado (o a mí me pasaba eso u) lo único que tienes que hacer es mover el objeto para que lo que quieres hacer mirror esté en el punto 0.
    Yo es que no paro, me gustaría mucho probarlo. Gracias por el dato, vamos a ver en un futuro.
    Dec 2003
    La mayor pega que tiene, y que es un handicap muy iomportante de cara a enfrentarse a otras alternaivas, es el seam que deja al esculpir con mirror geometry.
    Por lo demás, es rápido, rápido. Un saludo.
    Cuiño, cuiiiiño!!!!
    A mi, con un simple cubo de unas cuantas caras, le hago un mirror geometry, luego hago una simple extrusión a las caras seleccionadas, y en el mirror se me destroza la geometría, no sé si estaré haciendo algo mal. A ver si luego subo unas imágenes para que lo veáis. Gracias.
    Dec 2003
    Silo 2 public beta 10c
    Nueva versión, la 10c. Parece que han corregido en parte (o sea, no han corregido) el problema del seam al esculpir con simetría, y otros bugs. Anuncian que han rediseñado la web y el for, y que los colgaran en breve. ¿se acercara la esperada y retrasdísima release¿por cierto, que está beta es como la anterior, un trial de 30 días libre par todo el mundo.
    El enlace: silo 2 public beta 10c (Windows and Mac) - Silo user forums. Un saludo.
    Cuiño, cuiiiiño!!!!
    Muchas gracias de nuevo. Bajando.
    Victor Navone
    Chuck Jones
    John Lasseter
    Gracias. Entre lo del hexágono y esto, estoy la mar de contento.
    El problema al que me refería era el que muestro en la imagen, que sigue sin resolverse en esta versión. O lo mismo es que yo estoy haciendo algo mal. Gracias.
Nombre: silo_problem.jpg
Visitas: 165
Tamaño: 106.7 KB
    Publícalo en los foros de nevercenter.
    Yo es que me inclino porque estoy haciendo algo mal, no me parece lógico que el programa falle en algo tan básico y tan usado por todos, ya se habrían dado cuenta antes.
    Ya salió la 11a. Lo más interesante es que trae una documentación bastante útil. Se lo trabajaron.
    Dec 2003
    Gracias. Bajando.
    Cuiño, cuiiiiño!!!!
  16. #16
    Pues ahora no me acepta mi password, en las anteriores betas si. ¿Qué narices pasa?
  17. #17
    Dec 2003
    Te anarroseo de los foros de nevercenter: Please remember that your 1.4 registration codes Will not work todo register Silo 2 betas - You must use the beta in demo mode. Lo siento, but we get several emails each day from people inquiring why their 1.4 registration codes do not work on the beta :]. Un saludo.
    Cuiño, cuiiiiño!!!!
  18. #18
    No lo había leído, las letras eran demasiado grandes para mí. Gracias, me tenía preocupado porque estuve a punto de mandar email a nevercenter.
  19. #19
    Me sigue pasando lo del problema que comenté, la verdad es que no sé qué pasa.
  20. #20
    Dec 2003
    Pues a mí no se me ocurre que puede ser. Lo mejor que puedes hacer (si no lo has hecho ya) es consultarlo en los foros de nevercenter, o enviarles un mail directamente al staff de Silo.
    Por cierto, nadie dice nada del nuevo logotipo de Silo?
    Cuiño, cuiiiiño!!!!
  21. #21
    Es una.
  22. #22
    Pero antes de consultarlo en los foros de nevercenter, a vosotros os pasa lo mismo?
  23. #23
    May 2002
    Vaya, que cagada de logotipo, y que cagada de we, b. (imho). nevercenter, com - Silo 3d modeling gracias a dios es de los mejores programas 3d que hay.
    Última edición por damesqlo; 14-07-2007 a las 20:37
    Zalu3
    "Acepto todo tipo de crí*ticas en cualquiera de mis mensajes y cuanto más duras (constructivas) mejor"
  24. #24
    Dec 2003
    Vaya, pues a mi el logotipo me gusta, la web, sí que es cierto que les ha quedado cutronga. Un saludo.
    Cuiño, cuiiiiño!!!!
  25. #25
    El logotipo parece hecho por un crío me parece ridículo.
  26. #26
    Dec 2003
    Bueno, lo que se suele decir, para gustos, colores. Un saludo.
    Cuiño, cuiiiiño!!!!
  27. #27
    silo 2.0.5 beta download. Ojo, es solo el ejecutable, no un instalador, por lo tanto una vez descargado es cuestión de sustituir el exe instalado por este nuevo, previo backup, claro.
    Pc: http://www.silo3d.com/downloads/silo, beta_2_win.zip
    Mac: http://www.silo3d.com/downloads/silo, beta_2_mac.zip.
    feature updates.
    Displacement map export - Silo now exports displacement maps as well as Normal Maps. Were particularly looking for feedbak on this from those who use displacement maps regularly, as we havent had much chance todo test it yet.
    Merge tool - Weve added target weld functionality vía the merge command. It currently only works with vértices, but eventually wed like todo have it working with Edges as well. If nothing selected, calling merge Will enable the merge tool. With this tool, you can click on a vertex and drag it todo any other vertex todo merge those two vértices. Works with stick keys.
    Incremental save - Use this command todo quickly save your file with an incremented numbering system so you wont overwrite your previous save. Be sure todo chek the options todo tweak its behavior.
    Export subdivided Mesh - This option is now available for all file formats, so you can export the Mesh at the current subdivisión level without having todo refine it first. Incidentally, the file format settings are now accesible as part of the save options.
    Assign software selection Radius - You can now set the software selection Radius based on the current selection. For example, you can select two vértices todo define the Radius. It can be accessed vía the software selection options, or assigned directly todo a hotkey. (the command name is currently assing software selection Radius in the keyboard editor.) it a los works with a highlighted element, so if youve got a selection you can adjust the Radius by just highlighting a new element that the right distance away and calling the command vía hotkey.
    Separated UV commands - You can now pin, unpin, or toggle the Pinning of UV vértices, and Mark, unmark, or toggle the Marking of texture seam.
    bugs fixed.
    Crash when clicking in certain frame areas.
    Crash with Path extrusión object.
    Crash with brush resize of the screen.
    Merge doesnt mirror properly with vértices selected along/across seam.
    Models get smoothed out when they shouldnt due todo displacement painting.
    Export vertex normals with.obj.
    Select special geometry doesnt work in multi selection mode.
    UVS reversed.
    Selected UV proxies displaying incorrectly.
    Numerical editor Mac-specific issues.
    Save as, doesnt append file extensión, and defaults todo current file extensión.
    Non-native file formats now export instances as objects.
    Corrected subdivisión export todo.rib files.
    ? A testear.
    Victor Navone
    Chuck Jones
    John Lasseter
  28. #28
    Dec 2003
    Yahoo. Gracias boss.
    Cuiño, cuiiiiño!!!!
  29. #29
    Update para maqueros (copio y pego):
    hi folks. The 2.0.5 reléase for Mac introduced a Strange issue where users had todo manually enter the file extensión todo save a file. We believe weve corrected the issue, and wanted todo get you a quik update (2.0.51). Pléase give the installer a try and let us know if it works for you. . download here (Mac only).
    gracias for your help..
    Victor Navone
    Chuck Jones
    John Lasseter
  30. #30
    Empiezo a impacientarme, la nueva versión no va a salir nunca? La espera creo que está siendo demasiado larga.
  31. #31
    Están corrigiendo bugs y desarrollando una versión para Linux: habrá Silo para Linux - Foros 3dpoder..
    Victor Navone
    Chuck Jones
    John Lasseter
  32. #32
    Dec 2003
    Nueva beta (la 2.0.6) donde por lo visto han corregido bugs de visualización (especialmente para vista), y parece que les ha salido rana. No obstante: update march 5 2008 - Display bug fix beta - Silo user forums. Un saludo.
    Cuiño, cuiiiiño!!!!
  33. #33
    Que porculeras son las Ati, la gran mayoría de las tarjetas que daban problemas eran de esa marca.
    Victor Navone
    Chuck Jones
    John Lasseter
  34. #34
    Ahora que estoy probando Silo 2 un poco más profundamente, tiene varias cosas que no me gustan (o mejor dicho no tiene cosas que me gustan). Por un lado, no hay una manera fácil de unir dos vértices que están cruzados por una arista y que al conectarlos con alguna herramienta como append o Cut esta arista quede partida creando un nuevo vértice. Esto creo recordar que lo hacen max y modo, pero en Silo al menos no he encontrado la forma de hacerlo. Y otra cosa es que por muy lioso que parezca, la navegación con el track ball rotation te permite ver dónde su sistema no te permite.
    En fin, no se puede tener todo (bueno, modo lo tiene, pero la diferencia de precio es tan grande). Saludos.
  35. #35
    Por cierto, acaban de re-actualizar la 2.0.6. silo 2.0.6 reléase 3/13/08 - Silo user forums.
  36. #36
    Feb 2005
    Weje. Una duda que tengo, o más bien problema. Me metí en el foro de silo3d y encontré lo de las interfaz personalizadas, peor cuando las pongo pasa esto, alguien me puede ayudar.
Nombre: siloxz6.jpg
Visitas: 55
Tamaño: 17.6 KB
    Última edición por 3dpoder; 07-03-2012 a las 19:12
    www.anarkistudio.deviantart.com
    Anda pasate :mrgreen:
  37. #37
    Yo diría que es un problema de drivers de la tarjeta, del OpenGL o una combinación de ambas cosas. Pero tampoco me hagas mucho caso que no soy un experto.
  38. #38
    Dec 2003
    No descartes la posibilidad de que las imágenes de los iconos de esta personalización no estén guardadas en sus debidas carpetas. Un saludo.
    Cuiño, cuiiiiño!!!!
  39. #39
    Feb 2005
    Vaya? Porias explicármelo por favor?
  40. #40
    Pues supongo que, quiere decir que los (*.jpg) o lo que sea de los iconos tienen que estar guardadas en las carpetas que crea la instalación de Silo a tal efecto (que no sé cuáles son exactamente, tendría que mirarlas). Saludos.
    Edito: creo que es preferencias>icons.
  41. #41
    Silo 2.1 beta video demo.
    [size=+2]uv tools demo
    (10 Mb divx avi file).
    Victor Navone
    Chuck Jones
    John Lasseter
  42. #42
    silo 2.1 beta 6-20-2008 released.
    instalables (solo usuarios registrados): Windows: http://silo3d.com/downloads/silo_2_1._installer.zip.
    Mac: http://silo3d.com/downloads/silo_2_1.taller, pkg.zip.
    Victor Navone
    Chuck Jones
    John Lasseter
  43. #43
    Pero la beta esta para la que pones el enlace no se la puede bajar alguien que todavía no haya comprado el programa, ¿no? Me pide número de registro.
    Se han cargado los paneles laterales y han vuelto a la antigua interfaz?
    La verdad, me están empezando a cansar un poco estos de nevercenter, son lentos de cojones y parecen indecisos sobre que destino darle al software, que si arquitectura, que si ahora cambio la interfaz, además de que no acaban de arreglar algunos bugs. Saludos.
    Última edición por slash; 25-06-2008 a las 16:23
  44. #44
    Si, con usuarios registrados me refería a quienes tienen licencia.
    Victor Navone
    Chuck Jones
    John Lasseter
  45. #45
    Silo 2 Silo 2 release y avances betas
    silo 2.1 beta 7-28-2008 released.
    instalables (solo usuarios registrados): descarga (Windows)
    descarga (Mac).
    Victor Navone
    Chuck Jones
    John Lasseter
  46. #46
    silo 2.1 beta 07/ago/08. No instalables, se descomprime el contenido en la instalación de la versión previa. descarga (Mac). descarga (Windows).
    Y como segunda noticia, la wiki de Silo:
    http://nevercenter.com/wiki/index.ph..._modeling_wiki.
    Victor Navone
    Chuck Jones
    John Lasseter
  47. #47
    Apr 2006
    Muchas gracias Shazam, el enlace muy bueno voy a descargar Silo para probarlo. Un saludo.
  1. Blender 2.62 release y avances
    Por SHAZAM en el foro Noticias 3D
    Respuestas: 47
    : 27-04-2012, 18:51
  2. Blender 2.61 release y avances
    Respuestas: 64
    : 27-02-2012, 21:28
  3. Blender 2.60 release y avances
    Respuestas: 89
    : 14-12-2011, 20:29
  4. Blender 2.48 release y avances
    Respuestas: 558
    : 30-05-2009, 18:38
  5. Silo 2 release y avances
    Por elGordo en el foro Noticias 3D
    : 11-08-2007, 10:45
