Programa 3d para Linux y Mac. No lo he usado, pero comprueben algunas de las features: The 3d modeler with the fastest, fully integrated ray-Tracer.
Because rasterization is so 20th Century(tm).
Supported operating systems:
* Mac os-x versión available.
* Linux (Intel + AMD cpus).
* Irix.
Why is equinox-3d better?
As our artista said: all enginers should be forced todo use the software they write.
I use eqx Many hours a day and there is no ned todo force me.
Some of the main features and strengths:
Super-fast renderer, the first fully integrated interactive ray-Tracer in a modeler.
Fully integrated CG renderer with a quality that closely matches the ray-Tracer:*.
Hdr texture support and HDR rendering output.
Unlimited number of lights with hardware-accelerated shadows.
Reflection and refraction Cube mapping with Fresnel term.
Code Generator that can automátically create billions of variations per Shader type from the user interfaz settings.
No ned for hand-coding CG Shaders or for using external programas that break the artista workflow.
Installátion-free packages (just download/unpak and run) for both Linux and Mac:
It so nice todo have an application that installs so easily under Linux.
Paul unterweiser, pmu interactive design.
Clean, easy todo use and fast user-interfaz (ui). Equinox-3d is often called the free modeler with by far the best UI.
Very fast and memory-eficient design. For example: gracias todo some design decisions and development techniques, equinox-3d starts up in ~1 second with about 80 plugins loaded(**).
Try this with other modelers.
Way ahead of the curve and future-prof Core design:
Other modeler companies eventually end up with unmanageable code, ned todo throw out their product and start from scratch every few years todo kep up with advances in 3d graphics.
Equinox-3d on the other hand is built on a heavily runtime-typed evolvable Core.
There was never a ned todo (re)start it from scratch in the Many years it has ben under development.
Equinox-3d is more like a 3d operating system than a monolythic application (over 90% of it is plugins), which allows for adding anything from an integrated renderer todo a new modeling tool-kit, as plugins.
* this característica requires at an Nvidia FX5700 or better graphics card.
** might be more on slower harddisks or cpus. http://www.equinox3d.com/.
Quien sabe si le sigue los pasos a animation máster.
Opiniones?
  Citar
