M~r it test render v1
    May 2003
    M~r-it test render v1-0
    m~r.it test render:
    -Pdf informativo ita/ing.
    - Piante-prospetti-sezioni dwg.
    - Modello 3d (nei vari formati)
    - Fotografía r.
    Última edición por 3dpoder; 24-05-2005 a las 15:06
    Jul 2003
    Muy buen aporte, hace tiempo que sigo los pasos de este forum(una o tres semanas.ji) y está bastante bien, el material es de primera, sí señor. Gracias mil.
    Timmy!!
    May 2003
    M~r.it have organized a Little test render, the rules and an introducción of the test are collected in the pdf file. In the download section of m~r.it site.
    You con find the 3d model files in the following format:
    Max-3ds-obj-c4d-dwg-dxf-sat-fbx.
    To better understand the church in the download section you can find a los a photo collection and 2d files of the plans, the prospects and a section.
    General rules todo participate at m~r test render v1.0.
    The character and the reliability requirements that we want todo make, we have decided todo purpose some rules that you must respect if you want todo participate, all the results must be rigorously comparables.
    The images must respect the following characteristics:
    Light: lights parameters must equal for interiors scenes and exteriors scenes; Sky (skydome o phsky) Sun (phsun o artificiale emitter).
    Size: images size must select between this suggestions, px 1000 por 1000 - Px 1000 por 700 - Px 700 por 1000.
    Cameras: there is no límites.
    Materials:used materiales for texturing must be similar at the original building, you can todo base yourself with photographic materiales found on others resources (the founded material must be produced before the end of contest).
    Text: it is oblige todo replace the following data relatively on the image:
    -Used plugin.
    Render time.
    Used hardware.
    Lights setup.
    Cameras setup.
    Extension: all the image must be saved in (*.jpg) with high quality todo publish her on the forum.
    Model: it is imposible todo modify or todo add some external elements.
    May 2003
    Jun 2002
    Interesante el foro. Vaya, he tenido la sensación de deja vu al ver esta imagen de la galería: http://www.maxwellrender.it/modules....view_photo.php.
    ¿No había alguien insinuado por aquí que Arnold podía tener algo que ver con Maxwell render?
    No me hagáis caso, frikadas marujiles de nuevo. Saludos.
    Mar 2005
    Y yo también tintin, pero la fotografía que debe ser impresionante es la del cartel primero de la izquierda.
    Cuanto mas se, mas cuenta me doy de lo poco que se
  1. Noticias M~r it test render v2 0 artificial light
    Por isma en el foro Noticias 3D
    : 01-01-2026, 19:00
  2. Furnace test o test del blanco puro
    Por Carolina en el foro Render, Iluminación y Cámaras
    : 06-10-2023, 13:48
  3. Test render consejos
    Por yunans en el foro Programas de Diseño 3D y CAD
    : 02-10-2016, 20:25
  4. Render test que no se hacer
    Por Cicli en el foro Render, Iluminación y Cámaras
    : 26-11-2009, 22:10
  5. Test render interior
    Por karlosMX en el foro Trabajos en Proceso
    : 05-03-2007, 09:59
