Error de movimiento en mi código para Unity
    Dec 2023
    Hola, estoy continuando un trabajo sobre un juego Pokémon, y cuando estaba mejorando el código en Unity, me apareció este error:
    "You are trying to create a MonoBehaviour using the 'new' keyword. This is not allowed. MonoBehaviours can only be added using AddComponent(). Alternatively, your script can inherit from ScriptableObject or no base class at all."
    UnityEngine.MonoBehaviour:.ctor ()
    SpriteAnimator:.ctor (System.Collections.Generic.List`1<UnityEngine.Spr ite>, UnityEngine.SpriteRenderer, float) (at Assets/Scripts/Utils/SpriteAnimator.cs:14)
    CharacterAnimatortart () (at Assets/Scripts/CharacterAnimator.cs:36)
    Este es mi código:
    Character:
    using System.Collections;
    using System.Collections.Generic;
    using UnityEngine;
    public class Character : MonoBehaviour
    public float moveSpeed;
    CharacterAnimator animator;
    private void Awake()
    animator = GetComponent<CharacterAnimator>();
    public IEnumerator Move(Vector2 moveVec)
    animator.MoveX = moveVec.x;
    animator.MoveY = moveVec.y;
    var targetPos = transform.position;
    targetPos.x += moveVec.x;
    targetPos.y += moveVec.y;
    if(IsWalkable(targetPos))
    yield break;
    animator.IsMoving = true;
    while ((targetPos - transform.position).sqrMagnitude > Mathf.Epsilon)
    transform.position = Vector3.MoveTowards(transform.position, targetPos, moveSpeed * Time.deltaTime);
    yield return null;
    transform.position = targetPos;
    animator.IsMoving = false;
    private bool IsWalkable(Vector3 targetPos)
    if(Physics2D.OverlapCircle(targetPos, 0.01f, GameLayers.i.SolidLayer | GameLayers.i.InteractableLayer) != null)
    return false;
    return true;
    public CharacterAnimator Animator
    get => animator;
    PlayerScript:
    using UnityEngine;
    public class PlayerScript : MonoBehaviour
    private Vector2 input;
    private Character character;
    public VectorValue startingPosition;
    character = GetComponent<Character>();
    private void Start()
    transform.position = startingPosition.initialValue;
    public void HandleUpdate()
    if (!character.Animator.IsMoving)
    input.x = Input.GetAxisRaw("Horizontal");
    input.y = Input.GetAxisRaw("Vertical");
    if (input.x != 0) input.y = 0;
    if (input != Vector2.zero)
    StartCoroutine(character.Move(input));
    if (Input.GetKeyDown(KeyCode.E))
    Interact();
    private void Interact()
    var facingDir = new Vector3(character.Animator.MoveX, character.Animator.MoveY);
    var interactPos = transform.position + facingDir;
    Debug.DrawLine(transform.position, interactPos, Color.green, 1f);
    var collider = Physics2D.OverlapCircle(interactPos, 0.3f, GameLayers.i.InteractableLayer);
    if(collider != null)
    collider.GetComponent<Interactable>()?.Interact();
    CharacterAnimator:
    using UnityEngine;
    public class CharacterAnimator : MonoBehaviour
    [SerializeField] List<Sprite> walkDownSprites;
    [SerializeField] List<Sprite> walkUpSprites;
    [SerializeField] List<Sprite> walkRightSprites;
    [SerializeField] List<Sprite> walkLeftSprites;
    //parameters
    public float MoveX {get; set; }
    public float MoveY {get; set; }
    public bool IsMoving {get; set; }
    //states
    SpriteAnimator walkDownAnim;
    SpriteAnimator walkUpAnim;
    SpriteAnimator walkRightAnim;
    SpriteAnimator walkLeftAnim;
    SpriteAnimator currentAnim;
    bool wasPreviouslyMoving;
    SpriteRenderer spriteRenderer;
    spriteRenderer = GetComponent<SpriteRenderer>();
    walkDownAnim = new SpriteAnimator(walkDownSprites, spriteRenderer);
    walkUpAnim = new SpriteAnimator(walkUpSprites, spriteRenderer);
    walkRightAnim = new SpriteAnimator(walkRightSprites, spriteRenderer);
    walkLeftAnim = new SpriteAnimator(walkLeftSprites, spriteRenderer);
    currentAnim = walkDownAnim;
    private void Update()
    var prevAnim = currentAnim;
    if(MoveX == 1)
    currentAnim = walkRightAnim;
    else if(MoveX == -1)
    currentAnim = walkLeftAnim;
    else if (MoveY == 1)
    currentAnim = walkUpAnim;
    else if (MoveY == -1)
    if(currentAnim != prevAnim || wasPreviouslyMoving != IsMoving )
    currentAnim.Start();
    if(IsMoving)
    currentAnim.HandleUpdate();
    else
    spriteRenderer.sprite = currentAnim.Frames[0];
    wasPreviouslyMoving = IsMoving;
    Esto tendrías que probarlo en chatGPT
    Los códigos lo genera y los rectifica bastante bien.
    https://chat.openai.com/
  1. Error de movimiento en mi código para Unity
    Por sabionbot10 en el foro Unity
    : 07-12-2023, 19:02
  2. 3ds Max Error al exportar mi animación a Unity
    Por Heyoz en el foro Animación y Rigging
    : 31-10-2017, 23:37
  3. 3ds Max Cómo usar movimiento de Realviz para capturar movimiento
    Por masticas en el foro Animación y Rigging
    : 01-02-2017, 18:48
  4. 3ds Max Sugerencias con 3ds Max 2009 error código 26 no se encuentra el modulo especificado
    Por lux2010 en el foro Programas de Diseño 3D y CAD
    : 30-05-2010, 04:10
  5. Autodesk Maya Error,Maya todo con código binario
    Por nuevometropolis en el foro Programas de Diseño 3D y CAD
    : 09-03-2010, 23:03
