Problema con la instalación de 3ds Max
    Aug 2013
    problema con la instalación de 3ds Max
    Hola, tengo un problema con la instalación del 3ds Max, el cual es el siguiente:
Nombre: Sin título.png
Visitas: 1050
Tamaño: 281.8 KB
    Este es el Log file.
    2013/5/26:00:40:05 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===2013/5/26:00:40:05 Beto PTJ2004 Launch.
    2013/5/26:00:42:04 Beto PTJ2004 === Setup ended ===.
    2013/5/26:00:40:32 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/5/26:00:40:32 Beto PTJ2004 Launch.
    2013/5/26:00:40:58 Beto PTJ2004 PageOpen LaunchDialog.
    2013/5/26:00:48:26 Beto PTJ2004 === Setup ended ===.
    2013/5/26:00:48:47 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/5/26:00:48:47 Beto PTJ2004 Launch.
    2013/5/26:00:48:47 Beto PTJ2004 An instance of setup is already running. Only one instance of setup can run at a time.2013/5/26:00:50:29 Beto PTJ2004 === Setup ended ===.
    2013/5/26:01:02:56 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/5/26:01:02:56 Beto PTJ2004 Launch.
    2013/5/26:01:02:56 Beto PTJ2004 An instance of setup is already running. Only one instance of setup can run at a time.2013/5/26:01:03:19 Beto PTJ2004 === Setup ended ===.
    2013/5/26:01:04:10 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/5/26:01:04:10 Beto PTJ2004 Launch.
    2013/5/26:01:04:29 Beto PTJ2004 === Setup ended ===.
    2013/5/26:01:06:51 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/5/26:01:06:51 Beto PTJ2004 Launch.
    2013/5/26:01:06:51 Beto PTJ2004 An instance of setup is already running. Only one instance of setup can run at a time.2013/5/26:01:06:53 Beto PTJ2004 === Setup ended ===.
    2013/5/26:01:07:11 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/5/26:01:07:11 Beto PTJ2004 Launch.
    2013/5/26:01:07:19 Beto PTJ2004 === Setup ended ===.
    2013/7/31:18:33:03 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/7/31:18:33:03 Beto PTJ2004 Launch.
    2013/7/31:18:33:20 Beto PTJ2004 === Setup ended ===.
    2013/7/31:18:33:09 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/7/31:18:33:09 Beto PTJ2004 Launch.
    2013/7/31:18:33:20 Beto PTJ2004 PageOpen LaunchDialog.
    2013/7/31:18:33:35 Beto PTJ2004 PageOpen LicenseDialog.
    2013/7/31:18:33:38 Beto PTJ2004 PageOpen ProductInfoDialog.
    2013/7/31:18:34:44 Beto PTJ2004 PageOpen ProductSelectionDialog2.
    2013/7/31:18:34:55 Beto PTJ2004 PageOpen FullProgressDialog.
    2013/7/31:18:34:55 Beto PTJ2004 Installing DirectX Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent.
    2013/7/31:18:39:39 Beto PTJ2004 Install DirectX Runtime Succeded.
    2013/7/31:18:39:39 Beto PTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROT=C:\Users\Beto\Documents\3ds Max 2013 x64 JP\ FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2013/7/31:18:39:44 Beto PTJ2004 Install Autodesk Material Library 2013 Failed Installátion aborted, Result=2.
    2013/7/31:18:39:45 Beto PTJ2004 Rollbak DirectX Runtime Failed Failure is ignored, Result=1619.
    2013/7/31:18:39:48 Beto PTJ2004 PageOpen InstallCompleteDialog.
    2013/7/31:19:03:36 Beto PTJ2004 === Setup ended ===.
    2013/7/31:19:10:17 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/7/31:19:10:17 Beto PTJ2004 Launch.
    2013/7/31:19:10:51 Beto PTJ2004 === Setup ended ===.
    2013/7/31:19:10:34 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/7/31:19:10:34 Beto PTJ2004 Launch.
    2013/7/31:19:10:52 Beto PTJ2004 PageOpen LaunchDialog.
    2013/7/31:19:12:43 Beto PTJ2004 PageOpen LicenseDialog.
    2013/7/31:19:12:50 Beto PTJ2004 PageOpen ProductInfoDialog.
    2013/7/31:19:13:33 Beto PTJ2004 PageOpen ProductSelectionDialog2.
    2013/7/31:19:13:52 Beto PTJ2004 PageOpen FullProgressDialog.
    2013/7/31:19:13:52 Beto PTJ2004 Installing DirectX Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent.
    2013/7/31:19:20:53 Beto PTJ2004 Install DirectX Runtime Succeded.
    2013/7/31:19:20:53 Beto PTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROT=C:\Users\Beto\Documents\3ds Max 2013 x64 JP\ FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2013/7/31:19:20:56 Beto PTJ2004 Install Autodesk Material Library 2013 Failed Installátion aborted, Result=2.
    2013/7/31:19:20:58 Beto PTJ2004 Rollbak DirectX Runtime Failed Failure is ignored, Result=1619.
    2013/7/31:19:20:59 Beto PTJ2004 PageOpen InstallCompleteDialog.
    2013/7/31:19:41:04 Beto PTJ2004 === Setup ended ===.
    2013/8/1:13:49:15 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/1:13:49:15 Beto PTJ2004 Launch.
    2013/8/1:13:49:27 Beto PTJ2004 === Setup ended ===.
    2013/8/1:13:49:19 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/1:13:49:19 Beto PTJ2004 Launch.
    2013/8/1:13:49:28 Beto PTJ2004 PageOpen LaunchDialog.
    2013/8/1:13:49:41 Beto PTJ2004 PageOpen LicenseDialog.
    2013/8/1:13:50:06 Beto PTJ2004 PageOpen ProductInfoDialog.
    2013/8/1:13:50:53 Beto PTJ2004 PageOpen ProductSelectionDialog2.
    2013/8/1:13:51:02 Beto PTJ2004 PageOpen FullProgressDialog.
    2013/8/1:13:51:04 Beto PTJ2004 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /que /norestart.
    2013/8/1:13:51:38 Beto PTJ2004 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeded.
    2013/8/1:13:51:38 Beto PTJ2004 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /que /norestart.
    2013/8/1:13:51:49 Beto PTJ2004 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeded.
    2013/8/1:13:51:49 Beto PTJ2004 Installing DirectX Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent.
    2013/8/1:13:56:16 Beto PTJ2004 Install DirectX Runtime Succeded.
    2013/8/1:13:56:16 Beto PTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROT=C:\Users\Beto\Documents\3ds Max 2013 x64 JP\ FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2013/8/1:13:56:17 Beto PTJ2004 Install Autodesk Material Library 2013 Failed Installátion aborted, Result=2.
    2013/8/1:13:56:17 Beto PTJ2004 Rollbak DirectX Runtime Failed Failure is ignored, Result=1619.
    2013/8/1:13:56:17 Beto PTJ2004 Rollbak Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installátion aborted, Result=1619.
    2013/8/1:13:56:17 Beto PTJ2004 Rollbak Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installátion aborted, Result=1619.
    2013/8/1:13:56:19 Beto PTJ2004 PageOpen InstallCompleteDialog.
    2013/8/1:14:28:43 Beto PTJ2004 === Setup ended ===.
    2013/8/1:15:20:32 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/1:15:20:32 Beto PTJ2004 Launch.
    2013/8/1:15:20:48 Beto PTJ2004 === Setup ended ===.
    2013/8/1:15:20:39 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/1:15:20:39 Beto PTJ2004 Launch.
    2013/8/1:15:20:48 Beto PTJ2004 PageOpen LaunchDialog.
    2013/8/1:15:20:52 Beto PTJ2004 PageOpen LicenseDialog.
    2013/8/1:15:21:06 Beto PTJ2004 PageOpen ProductInfoDialog.
    2013/8/1:15:21:37 Beto PTJ2004 PageOpen ProductSelectionDialog2.
    2013/8/1:15:21:44 Beto PTJ2004 PageOpen FullProgressDialog.
    2013/8/1:15:21:44 Beto PTJ2004 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q.
    2013/8/1:15:21:51 Beto PTJ2004 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeded.
    2013/8/1:15:21:51 Beto PTJ2004 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q.
    2013/8/1:15:22:20 Beto PTJ2004 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeded.
    2013/8/1:15:22:20 Beto PTJ2004 Installing DirectX Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent.
    2013/8/1:15:28:31 Beto PTJ2004 Install DirectX Runtime Succeded.
    2013/8/1:15:28:31 Beto PTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROT=C:\Users\Beto\Documents\3ds Max 2013 x64 JP\ FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2013/8/1:15:28:31 Beto PTJ2004 Install Autodesk Material Library 2013 Failed Installátion aborted, Result=2.
    2013/8/1:15:28:32 Beto PTJ2004 Rollbak DirectX Runtime Failed Failure is ignored, Result=1619.
    2013/8/1:15:28:32 Beto PTJ2004 Rollbak Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installátion aborted, Result=1619.
    2013/8/1:15:28:32 Beto PTJ2004 Rollbak Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installátion aborted, Result=1619.
    2013/8/1:15:28:35 Beto PTJ2004 PageOpen InstallCompleteDialog.
    2013/8/1:15:30:35 Beto PTJ2004 === Setup ended ===.
    2013/8/1:15:47:07 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/1:15:47:07 Beto PTJ2004 Launch.
    2013/8/1:15:47:15 Beto PTJ2004 === Setup ended ===.
    2013/8/1:15:47:10 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/1:15:47:10 Beto PTJ2004 Launch.
    2013/8/1:15:47:15 Beto PTJ2004 PageOpen LaunchDialog.
    2013/8/1:15:47:19 Beto PTJ2004 PageOpen LicenseDialog.
    2013/8/1:15:47:29 Beto PTJ2004 PageOpen ProductInfoDialog.
    2013/8/1:15:48:33 Beto PTJ2004 PageOpen ProductSelectionDialog2.
    2013/8/1:15:48:45 Beto PTJ2004 PageOpen FullProgressDialog.
    2013/8/1:15:48:45 Beto PTJ2004 Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.e xe /q:a /T:C:\Windows\temp /c:VCREDI~3. EXE /q:a /c:msiexec /i vcredist, MSI /qn /l*v C:\Users\Beto\AppData\Local\Temp\vcredist_x86_2005 .log.
    2013/8/1:15:49:11 Beto PTJ2004 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeded.
    2013/8/1:15:49:11 Beto PTJ2004 Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.e xe /q:a /T:C:\Windows\temp /c:VCREDI~2. EXE /q:a /c:msiexec /i vcredist, MSI /qn /l*v C:\Users\Beto\AppData\Local\Temp\vcredist_x64_2005 .log.
    2013/8/1:15:49:39 Beto PTJ2004 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeded.
    2013/8/1:15:49:39 Beto PTJ2004 Installing DirectX Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent.
    2013/8/1:15:57:49 Beto PTJ2004 Install DirectX Runtime Succeded.
    2013/8/1:15:57:50 Beto PTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROT=C:\Users\Beto\Documents\3ds Max 2013 x64 JP\ FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2013/8/1:15:57:50 Beto PTJ2004 Install Autodesk Material Library 2013 Failed Installátion aborted, Result=2.
    2013/8/1:15:57:50 Beto PTJ2004 Rollbak DirectX Runtime Failed Failure is ignored, Result=1619.
    2013/8/1:15:57:50 Beto PTJ2004 Rollbak Microsoft Visual C++ 2005 Redistributable (x64) Failed Installátion aborted, Result=1619.
    2013/8/1:15:57:50 Beto PTJ2004 Rollbak Microsoft Visual C++ 2005 Redistributable (x86) Failed Installátion aborted, Result=1619.
    2013/8/1:15:58:09 Beto PTJ2004 PageOpen InstallCompleteDialog.
    2013/8/1:15:58:51 Beto PTJ2004 === Setup ended ===.
    2013/8/1:16:36:24 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/1:16:36:24 Beto PTJ2004 Launch.
    2013/8/1:16:36:37 Beto PTJ2004 === Setup ended ===.
    2013/8/1:16:36:51 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/1:16:36:51 Beto PTJ2004 Launch.
    2013/8/1:16:36:51 Beto PTJ2004 An instance of setup is already running. Only one instance of setup can run at a time.2013/8/1:16:36:52 Beto PTJ2004 === Setup ended ===.
    2013/8/1:16:36:33 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/1:16:36:33 Beto PTJ2004 Launch.
    2013/8/1:16:36:37 Beto PTJ2004 PageOpen LaunchDialog.
    2013/8/1:16:36:42 Beto PTJ2004 PageOpen LicenseDialog.
    2013/8/1:16:36:45 Beto PTJ2004 PageOpen LaunchDialog.
    2013/8/1:16:38:29 Beto PTJ2004 PageOpen LicenseDialog.
    2013/8/1:16:38:29 Beto PTJ2004 PageOpen ProductSelectionDialog2.
    2013/8/1:16:38:43 Beto PTJ2004 PageOpen FullProgressDialog.
    2013/8/1:16:38:46 Beto PTJ2004 Installing Autodesk 3ds Max 2013 SDK: TRANSFORMS=C:\Users\Beto\AppData\Local\Temp\_AIBAB A.tmp\x86\Tools\MAXSDK\SDK_3dsMax2013-standalone, mst ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROT=C:\Users\Beto\Documents\3ds Max 2013 x64 JP\ INSTALLDIR=C:\Program Files (x86)\Autodesk\ FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2013/8/1:16:38:46 Beto PTJ2004 Install Autodesk 3ds Max 2013 SDK Failed Failure is ignored, Result=2.
    2013/8/1:16:38:46 Beto PTJ2004 Installing Network License Manager: ALLUSERS=1 INSTALLDIR=C:\Program Files\Autodesk\Autodesk Network License Manager\ ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROT=C:\Users\Beto\Documents\3ds Max 2013 x64 JP\ FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2013/8/1:16:38:46 Beto PTJ2004 Install Network License Manager Failed Failure is ignored, Result=2.
    2013/8/1:16:38:46 Beto PTJ2004 PageOpen InstallCompleteDialog.
    2013/8/1:16:47:04 Beto PTJ2004 === Setup ended ===.
    2013/8/1:17:03:52 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/1:17:03:52 Beto PTJ2004 Launch.
    2013/8/1:17:04:11 Beto PTJ2004 === Setup ended ===.
    2013/8/1:17:04:06 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/1:17:04:06 Beto PTJ2004 Launch.
    2013/8/1:17:04:11 Beto PTJ2004 PageOpen LaunchDialog.
    2013/8/1:17:23:06 Beto PTJ2004 PageOpen LicenseDialog.
    2013/8/1:17:23:24 Beto PTJ2004 PageOpen ProductInfoDialog.
    2013/8/1:17:24:10 Beto PTJ2004 PageOpen ProductSelectionDialog2.
    2013/8/1:17:24:13 Beto PTJ2004 PageOpen FullProgressDialog.
    2013/8/1:17:24:14 Beto PTJ2004 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /que /norestart.
    2013/8/1:17:24:40 Beto PTJ2004 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeded.
    2013/8/1:17:24:40 Beto PTJ2004 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /que /norestart.
    2013/8/1:17:24:53 Beto PTJ2004 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeded.
    2013/8/1:17:24:53 Beto PTJ2004 Installing DirectX Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent.
    2013/8/1:17:27:59 Beto PTJ2004 Install DirectX Runtime Succeded.
    2013/8/1:17:27:59 Beto PTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROT=C:\Users\Beto\Documents\3ds Max 2013 x64 JP\ FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2013/8/1:17:28:00 Beto PTJ2004 Install Autodesk Material Library 2013 Failed Installátion aborted, Result=2.
    2013/8/1:17:28:01 Beto PTJ2004 Rollbak DirectX Runtime Failed Failure is ignored, Result=1619.
    2013/8/1:17:28:01 Beto PTJ2004 Rollbak Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installátion aborted, Result=1619.
    2013/8/1:17:28:01 Beto PTJ2004 Rollbak Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installátion aborted, Result=1619.
    2013/8/1:17:28:04 Beto PTJ2004 PageOpen InstallCompleteDialog.
    2013/8/1:17:47:22 Beto PTJ2004 === Setup ended ===.
    2013/8/1:18:25:03 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/1:18:25:03 Beto PTJ2004 Launch.
    2013/8/1:18:25:21 Beto PTJ2004 === Setup ended ===.
    2013/8/1:18:25:09 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/1:18:25:09 Beto PTJ2004 Launch.
    2013/8/1:18:25:21 Beto PTJ2004 PageOpen LaunchDialog.
    2013/8/1:18:25:23 Beto PTJ2004 PageOpen LicenseDialog.
    2013/8/1:18:25:32 Beto PTJ2004 PageOpen ProductInfoDialog.
    2013/8/1:18:26:17 Beto PTJ2004 PageOpen ProductSelectionDialog2.
    2013/8/1:18:27:11 Beto PTJ2004 PageOpen FullProgressDialog.
    2013/8/1:18:27:11 Beto PTJ2004 Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.e xe /q:a /T:C:\Windows\temp /c:VCREDI~3. EXE /q:a /c:msiexec /i vcredist, MSI /qn /l*v C:\Users\Beto\AppData\Local\Temp\vcredist_x86_2005 .log.
    2013/8/1:18:28:26 Beto PTJ2004 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeded.
    2013/8/1:18:28:26 Beto PTJ2004 Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.e xe /q:a /T:C:\Windows\temp /c:VCREDI~2. EXE /q:a /c:msiexec /i vcredist, MSI /qn /l*v C:\Users\Beto\AppData\Local\Temp\vcredist_x64_2005 .log.
    2013/8/1:18:28:43 Beto PTJ2004 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeded.
    2013/8/1:18:28:43 Beto PTJ2004 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q.
    2013/8/1:18:28:52 Beto PTJ2004 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeded.
    2013/8/1:18:28:52 Beto PTJ2004 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q.
    2013/8/1:18:29:01 Beto PTJ2004 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeded.
    2013/8/1:18:29:01 Beto PTJ2004 Installing DirectX Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent.
    2013/8/1:18:34:54 Beto PTJ2004 Install DirectX Runtime Succeded.
    2013/8/1:18:34:54 Beto PTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROT=C:\Users\Beto\Documents\3ds Max 2013 x64 JP\ FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2013/8/1:18:34:55 Beto PTJ2004 Install Autodesk Material Library 2013 Failed Installátion aborted, Result=2.
    2013/8/1:18:34:56 Beto PTJ2004 Rollbak DirectX Runtime Failed Failure is ignored, Result=1619.
    2013/8/1:18:34:56 Beto PTJ2004 Rollbak Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installátion aborted, Result=1619.
    2013/8/1:18:34:57 Beto PTJ2004 Rollbak Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installátion aborted, Result=1619.
    2013/8/1:18:34:57 Beto PTJ2004 Rollbak Microsoft Visual C++ 2005 Redistributable (x64) Failed Installátion aborted, Result=1619.
    2013/8/1:18:34:57 Beto PTJ2004 Rollbak Microsoft Visual C++ 2005 Redistributable (x86) Failed Installátion aborted, Result=1619.
    2013/8/1:18:35:00 Beto PTJ2004 PageOpen InstallCompleteDialog.
    2013/8/1:18:35:57 Beto PTJ2004 === Setup ended ===.
    2013/8/1:19:05:34 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/1:19:05:34 Beto PTJ2004 Launch.
    2013/8/1:19:07:58 Beto PTJ2004 === Setup ended ===.
    2013/8/1:19:07:51 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/1:19:07:51 Beto PTJ2004 Launch.
    2013/8/1:19:07:59 Beto PTJ2004 PageOpen LaunchDialog.
    2013/8/1:19:08:28 Beto PTJ2004 PageOpen LicenseDialog.
    2013/8/1:19:08:35 Beto PTJ2004 PageOpen ProductInfoDialog.
    2013/8/1:19:10:05 Beto PTJ2004 PageOpen ProductSelectionDialog2.
    2013/8/1:19:10:12 Beto PTJ2004 PageOpen FullProgressDialog.
    2013/8/1:19:10:12 Beto PTJ2004 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /que /norestart.
    2013/8/1:19:10:25 Beto PTJ2004 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeded.
    2013/8/1:19:10:25 Beto PTJ2004 Installing DirectX Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent.
    2013/8/1:19:14:17 Beto PTJ2004 Install DirectX Runtime Succeded.
    2013/8/1:19:14:17 Beto PTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROT=C:\Users\Beto\Documents\3ds Max 2013 x64 JP\ FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2013/8/1:19:14:19 Beto PTJ2004 Install Autodesk Material Library 2013 Failed Installátion aborted, Result=2.
    2013/8/1:19:14:20 Beto PTJ2004 Rollbak DirectX Runtime Failed Failure is ignored, Result=1619.
    2013/8/1:19:14:20 Beto PTJ2004 Rollbak Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installátion aborted, Result=1619.
    2013/8/1:19:14:24 Beto PTJ2004 PageOpen InstallCompleteDialog.
    2013/8/1:21:23:40 Beto PTJ2004 === Setup ended ===.
    2013/8/2:14:27:52 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/2:14:27:52 Beto PTJ2004 Launch.
    2013/8/2:14:28:10 Beto PTJ2004 === Setup ended ===.
    2013/8/2:14:28:04 Beto PTJ2004 === Setup started on PTJ2004 by Beto ===.
    2013/8/2:14:28:04 Beto PTJ2004 Launch.
    2013/8/2:14:28:11 Beto PTJ2004 PageOpen LaunchDialog.
    2013/8/2:14:33:11 Beto PTJ2004 PageOpen LicenseDialog.
    2013/8/2:14:33:25 Beto PTJ2004 PageOpen ProductInfoDialog.
    2013/8/2:14:35:05 Beto PTJ2004 PageOpen ProductSelectionDialog2.
    2013/8/2:14:50:47 Beto PTJ2004 PageOpen FullProgressDialog.
    2013/8/2:14:50:48 Beto PTJ2004 Installing DirectX Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent.
    2013/8/2:14:56:22 Beto PTJ2004 Install DirectX Runtime Succeded.
    2013/8/2:14:56:22 Beto PTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROT=C:\Users\Beto\Documents\3ds Max 2013 x64 JP\ FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2013/8/2:14:56:26 Beto PTJ2004 Install Autodesk Material Library 2013 Failed Installátion aborted, Result=2.
    2013/8/2:14:56:27 Beto PTJ2004 Rollbak DirectX Runtime Failed Failure is ignored, Result=1619.
    Ayuda por favor.
    Jun 2010
    Creo que es un error causado por archivos de versiones anteriores del programa, intenta borrar todo archivo antes de instalar en especial la carpeta /3ds Max de Documentos (C:\Users\Beto\Documents\3ds Max 2013 x64 JP\).
    Te dejo un link:
    http://blog.microcad.info/como-elimi...stema-Windows/.
    Oct 2002
    ¿en japones? Que jefe.
    Igual le diste dos veces al botón de instalar, por algún lado del log ley que había dos instancias del instalador ejecutandose a la vez. Saludos.
    De todos modos, los señores de Autodesk podrán ayudarte mejor que nosotros.
    Aug 2013
    Cita Iniciado por davdickie16 Ver mensaje
    Te dejo un link:
    Eh borrado todo lo relacionado con archivos instalados de Autodesk, utilice el Revo Unistaller para quitar todo tipo de archivo y registro relacionados. Esa carpeta es la única y es la qué contiene los archivos de la instalación junto con el Setup.
    Cita Iniciado por Fiz3d Ver mensaje
    El último intento que realice fue para poder sacar la captura y el Log, pero eh intentado de muchas formas previamente y me da el mismo error. Estuve buscando en los foros de Autodesk y encontré que este problema les ah ocurrido con otros softwares de esta compañía y el error proviene por el Microsfot C++, eh tratado de hacer las soluciones que es eliminar todas esas librerías, pero el error continua, por eso acudí a este foro para ver si alguien tenía alguna solución. Muchas gracias a los dos por sus respuestas.
  1. RealFlow Problema de instalación
    Por comcom.com en el foro Partículas y Dinámicas
    : 14-08-2015, 07:59
  2. 3dsMax Problema instalación 3ds Max 2011
    Por cuevas957 en el foro Programas de Diseño 3D y CAD
    : 16-12-2010, 21:30
  3. 3dsMax Problema instalación 3ds Max 9
    Por Marinirini86 en el foro Programas de Diseño 3D y CAD
    : 18-10-2010, 18:25
  4. 3dsMax Problema con la instalación de 3ds Max 4
    Por ISSLA en el foro Programas de Diseño 3D y CAD
    : 11-03-2009, 23:43
  5. 3dsMax Problema con instalación 3ds Max
    Por AnimuS en el foro Programas de Diseño 3D y CAD
    : 21-07-2007, 07:37
