Ya disponible Thinking Particles 5 update 1. http://www.cebas.com/?Pid=hot_news&nid=508.
Muchas novedades incluidas relacionadas con demolition master.
- new feature: particle groups have a new chek box: do not cache, which excludes all particles of this group during caché récord. This flag is meant for helper or control particles, which are usually not sen in a rendering.
Clever use of this característica Will reduce caché sizes by a magnitude.- demolition master is a third party tampoco solution that allows easy, automatic complex destruction effects with thinkingparticles. Built in FumeFX support is a los available with demolition master.
- new feature: simulation caché now displays more información while recording. The progress bar shows context, file size, particle count recorded per subsample, time passed and estimation time todo finish recording.
- Final Render advanced instancing característica displayed errors when used with tampoco in the form of incorrect material assignments. This issue has ben isolated and is now fixed.
- unicode issues caused by 3ds Max 2013 when using demolition master as well as combo dropdown lists values showing foreign characters have ben detected and addressed.
- disable redraw while caching works more accurately and is more robust.
- tp volumebreaker Mesh-update in combination with the intersect operator is now repaired.
- large number of particles used in combination with the intersect node no longer results in memory issues or crashes.
- blackboxes containing a memory node in 3ds Max 2013 no longer crash on load.
- the internal function intersect ray used by Many tampoco nodes no longer creates a crash in extreme situations.
- bulletphysics now better defines and responds todo the change from the kinematic state todo the active state.
- new feature: Maxscript calls have ben added todo control the export node. New methods are: export() and remove ().
Citar
