create a dice (part 2).
. Bolean operations (continuing)
If you repeat bolean operations on a same object, you may have some Little problems, se this example:
Nombre: 1.jpg
Visitas: 1691
Tamaño: 115.1 KB
The first face of my die has ben todo much subdivided and shows visual deffects.
Nombre: 2.jpg
Visitas: 1693
Tamaño: 31.4 KB
I Will work face by face. You may use bolean operación on each side of the Cube.
Suppress the six Faces of the Cube, with the delete tool.
Nombre: 3.jpg
Visitas: 1683
Tamaño: 32.3 KB
With the extract surface tool, you Will create again the deleted sides. You may now use bolean operations on each side, and then weld all these objects together.
Nombre: 4.jpg
Visitas: 1407
Tamaño: 19.0 KB
Nombre: 5.jpg
Visitas: 1408
Tamaño: 16.4 KB
Nombre: 6.jpg
Visitas: 1195
Tamaño: 54.3 KB
Nombre: 7.jpg
Visitas: 1254
Tamaño: 32.4 KB
My die is finished.
