Modo 601 con rigging the personajes
    Wink Modo 601 con rigging the personajes
    http://www.luxology.com/modo/601/tour/. Character animation: modo ofers a range of character animation functionality from easy-to-use posing tools todo the creation of fully articulated character rigs that can be manipulated th rouge a full-body Inverse Kinematics Solver and a general purpose system of Layered deformers. http://www.animationmagazine.net/VFX...ases-modo-601/. http://www.luxology.com/modo/601/tour/index.aspx. Gracias a todos los programas por estar presentes, abran paso a modo 601 con esqueletos, y deformadores.
    Blog con mis practicas de animación:
    http://visualbug.wordpress.com/
    mi pagina web: http://visualbug.com/
    Modo 601 principales mejoras
    Algunas de las principales mejoras:
    Deformadores y animación de personajes.
    Skeleton tool/Mesh Binding.
    Full-body Inverse Kinematics.
    Pose tool.
    Pose space sculpting.
    Actors with poses and actions.
    Visible motion paths.
    Deformers.
    Fallofs as deformers.
    Textured fallofs.
    Alembic support.
    Md driven object deformation.
    Dinamicas.
    Bullet physics library engine.
    Rigid body dynamics.
    Software body dynamics.
    Modelado.
    Dedicated re-topology modeling tools and viewport.
    Topology Pen tool.
    Pixar subdivisión surfaces improvements.
    Preserve uvs.
    Mesh cleanup.
    New geometry constraint point mode.
    Software selection fallof.
    Lazy selection.
    Vertex map painting.
    Workflow.
    Matcap materiales.
    Silhouette view.
    Enhanced render view.
    3d Paint performance.
    Render within a capped time limit.
    3d mouse support.
    Rendering.
    Render booleans.
    Sky portals.
    Rounded Edge shader.
    Texture bombing (texture replicator).
    Oren-nayer Diffuse roughness Shading.
    Subsurface Scattering depth control.
    Camera clipping (by surface or material).
    Render passes.
    Preview renderer improvements.
    Spectral samples.
    Shading.
    Skin shader.
    Hair shader.
    Cel shader.
    Volúmenes y replicators.
    Volumetric rendering.
    Volumetric rendering (clouds).
    Replicator improvements.
    RealFlow support.
    Blobs.
    Particle painting/sculpting.
    Volumetric sprites.
    Dec 2007
    Qué buena noticia. Me gusta que también hayan incluido dinámicas. He estado viendo todos los vídeos, y para los de animación de personajes quizás se lo deberían haber currado un poco más para presentar la nueva versión. Hay algunas animaciones demasiado toscas. Con esto no quiero decir que las herramientas sean malas. Un saludo compañeros.
    "Todo lo que merece ser enseñado no merece ser aprendido"
    Blog- http://www.theguybrusher.blogspot.com/
    Thumbs up Modo 601 versión trial para descarga
    Luxology anuncia que la versión trial de modo 601 en su versión básica ya está disponible para descarga, la mala noticia es que sólo dan 15 días de pruebas.
  1. Autodesk Maya Rigging de personajes
    Por Ar@v3na 3D en el foro Animación y Rigging
    : 14-07-2025, 14:47
  2. Modo Kit de configuración automática de personajes en Modo
    : 13-12-2021, 19:20
  3. Modo Kit de configuración automática de personajes en Modo
    : 13-12-2020, 13:17
  4. 3ds Max Rigging muy barato de tus personajes
    Por zeroz en el foro Animación y Rigging
    : 07-02-2012, 19:58
  5. Rigging de personajes en 3ds Max
    Por Jesús Benitez López en el foro Oferta y demanda profesional
    : 07-10-2009, 23:17
